customh2
Everything posted by customh2
  1. Hmm, I'd try a cheap analog meter (with the little needle, not digital) across the pickup coil (left side of engine, under the round cover with 4 screws), check the resistance first (ohms), you should get some continuity reading, (unplugged if course) then spin it up (starter), the needle on the meter should flicker to show you're getting signal. I've seen many vehicles (especially bikes) where this pickup coil failed causing these exact symptoms, sometimes the wires chafed or cracked and grounds the signal out too. good luck
  2. customh2 replied to mayne222's topic in Naked
    I'm a programmer and web developer, I can start next week and build a searchable database online, would really be nice though if this site could host it's own. I don't mind building it either way. I'll host it on one of my sites then I'll give them a copy if they want to host it here.
  3. Cheers all, new member here: I have a 94 Seca2 XJ600rebuilt from crash parts which had been sitting for years (lots of work and constant maintenance). My current issue is the crankshaft oil seal (left side behind ignition rotor), manuals show lipped seal, I understand new seal doesn't have a lip to allow replacement without splitting crankcase, however, can I remove the old one without splitting the crankcase? PS I do have wiring diagrams I could email (downloaded the manual pdf from somewhere, I don't remember where or I'd post the link)
  4. customh2 replied to Mr Creosote's topic in Naked
