Kelum
Everything posted by Kelum
  1. Thank you guys, this morning battery is in very good condition, but once I press the start button if it shouldnt start at once, then again I will have the same problem..wish to go to electrician now... Chris...I charged battery yesterday and checked voltage which was around 12.5..then I installed it and rode..however at night when I was returning the high beam was on and it began to become dim, the hone started to whisper...this proves that the battery was giving off its power only, it wasnt charging... Thank you all for the helping words, I will update the thread once I got it solved..as for Christofesor, I dont think it will heal itself...plus I dont wanna get into trouble when I cruise in the country...no garages, no petrol,no street lamps etc...hehe
  2. Hi thanx mate, all these issues can happen due to low battery? regulator rectifier is the thing with a pinned heatsink at right side ? It was hot at the garage today..is it very pricey? damn will have to go here and there to find a right one right?
  3. I guess when the battery is low the spark plugs do not work well, thats why irregular sound and feel of engine and ultimate engine stops..am I right? Bike computer and firing orders etc get affected when battery is dead? Where is the choke? I found some cable with a leaver with N marked on plastic handle on right air cleaner ( I think those two ball-like structures at front sides are air cleaners)When do I have to use the choke and what position..? I found another red button at left front side on handle? What is the puprose of that?
  4. Hi all, I bought this cool bike few days ago and I am the third user, the year of manufacture of the bike is 2004. But early owners have had some damages on the bike, like the silencers have some strange corrosion (holes underside, just like some acid has made them) and chopped appearance but they dont seem to affect much as engine sound is just fine. This morning after running around 30 killometers I washed the bike. Then left water to drain, I washed all the cylinder heads. All the spark plugs were wet. Then after some time I tried to start the bike but the starter moter could not start the bike, I kept trying later I heard the moter revolving...without any "brass" sound. Later moter stopped responding to the switch..(I think my attempt drew lot of battery power) Then I pushed the bike and started it. At the electrician, battery was found to be low and it was charged, after connecting it back, the starter worked fine..at this condition I left home and came around 9pm..on the way I felt the head light was low..then before long I found that the battery was running extremely law ..then I externally charged the battery and put it in..after charging the functions of the bike were back to normal, I could start the bike so easily... The joy lasted few hours as I found battery was weak once again and I had to push the bike to start..running doesnt seem to charge the battery as the horns and headlights started to become dim (well, horn started to sound weaker and weaker)...according to electrician, battery is ok..when the battery is getting lower despite running, that means it doesnt charge...is it the alternator of the bike or something else causing the problem? can a current leak cause this? Will the repair will be pricey? When the battery is down, the engine stops functioning..and the engine seems to miss as the garage guys say..you can feel how odd each piston works as the bike starts to jump forward suddenly rather than having an smooth operation...is it the weak battery that causes this..once the battery was weak I turned off switch for sometime and pushed on highway, after sometime I turned on the switch and pushed along slopes and turned on first gear, the bike started easily and runs for around two killometers till the battery gets weaker again, even you can hear the horn and the headlight will get dimmer at this point.. I cant find the user manual for xv125..if someone have it please can you give me? I hope the issue is a lighter one and could get it fixed at a very low cost... Please help me and if something isnt clear please ask me..I am no native English guy...forgive me for errors. Another question is how can the underside of silencer have holes just like an acid would do...how can I prevent it? Can I weld them and perhaps weld and close all the holes? Can you apply some paint to hide welds? Thank you in advance...
