slice
YOC Member
Everything posted by slice
  1. That's about 19 Ft Lbs of torque, sorry I'm old, but are you saying they are loose or that they stick out from the Hub? If they are loose then you have to nip them down to the right setting but if they are sticking out you probably have the wrong bolts in there or the threads are damaged perhaps, if your worried then your best bet is to take it off and have a look at it DON'T guess LOOK. You say that "some were left loose" to get the plate flush, that is obviously wrong so your going to have to take it off and have a look at the problem, these are the sort of short cuts you use on the side of the road to get you home cos if you leave it as a long term fix they usually bite you in the arse.
  2. Hi Malleus, welcome to the YOC.
  3. slice replied to meatloaf's topic in General
    Er yeah I think the "padded bra" might be something he can perhaps NOT use, unless he likes the idea of course ! Takes all sorts.
  4. slice replied to meatloaf's topic in General
    I have the Bering kit Meat, good thermal and water proofing plus the armour is really well fitted, costs an arm and a leg tho but my old hide is to brittle to go down the cheap route.
  5. slice replied to paul tucker 73's topic in General
    Well done again Paul, a long slog but your getting close.
  6. Hi Costis, welcome to the YOC.
  7. No me neither, be an idea if you said Hello in the new members section? Bike sounds nice tho.
  8. You would be surprised Kev, they are nippy little buggers and can give you a fright if you've not ridden one. Seen them loaded with tents camping gear and 2 up, not flying up hill but certainly not crawling either.
  9. slice replied to mudcow007's topic in Classics
    I have a feeling that the neighbours will notice a 100 ounces of shrapnel exiting his garden shed Kev !!
  10. slice replied to mudcow007's topic in Classics
    I was thinking that with it in gear you can't rotate the crank, or have I got that wrong? If the clutch is a gear driven one and not a chain of course.
  11. slice replied to mudcow007's topic in Classics
    Yeah that would work, hammer out the middle and knock as much away as you can. Tho not sure what that would actually achieve as all you would have is a stuck piston with a big hole in it? Getting it out of gear or disconnected from the gear box would give you some ability to move the piston which you can't at the moment if it's stuck in gear, you could then hammer the piston down the barrel with nothing else connected. Just a thought.
  12. Sorry to hear that Drewpy, I have son's and they hurt as well, there are times a bang on the head for the offending partner would not go amiss, she will learn from this mate hopefully her next friend won't be such an arsehole !
  13. Helcrucho put this in the WORKSHOP section NOT on someones Hello post ! Perhaps a MOD would be kind enough to move it?
  14. Hi Ander, welcome to the YOC.
  15. Hi Cozi, welcome to the YOC.
  16. slice replied to mudcow007's topic in Classics
    Soak the barrel in diesel over night to loosen the piston, then heat the barrel. Should work but you might have to do it a few times. Steel plate over the top of the piston, your local engineers should have some plate knocking about, get them to cut you a lump to fit inside the hole.
  17. Hi Scrumpy, Welcome to the YOC.
  18. slice replied to blackhat250's topic in Random
    Sorry folks your wrong, I like Rossi followed his career for years and he was WRONG, what he did was dangerous regardless of the provocation (if any) I was told when I first started road racing that if you were to force another rider off the road deliberately you were finished right there right now, Rossi should have been disqualified and pulled from the track, I don't care he's the G O A T right now he's wrong.
  19. slice replied to junglecat's topic in The Bar
    Fraid you have come up against the "we don't sell those separately" syndrome, I bet they are supplied by an outside manufacturer and they have no control over the item other than to order a complete one, if you know who makes it (for Yamaha) you might get lucky and they will supply it direct to you but my bet is you can't and they won't.
  20. Hi Ken, welcome to the YOC.
  21. A plan is always nice mate, hope you make it.
  22. slice replied to andrewed1's topic in Projects
    Oh FFS that head stock has never been greased, at least not since it was in the factory, it's a wonder it never locked in place. At least the lower forks look better now (well done) if it was mine I would do the brakes anyway as the PO seems a bit of a tit. While you have it apart check that the brake hoses are not stretched or cracked, if they bulge when you apply the brakes they need to be replaced, I bet they were the originals, if you do decide to replace them buy stainless steel wrapped ones, a bit more expensive but give you a much better feeling brake. Nice job so far keep it up. Something like this
  23. As NSD say's fit a set of bar risers, just had a set on mine and the difference is just amazing, more adjustable than the originals and much more upright stance when riding, the whole bike feels different and more responsive. Some are really expensive but if your smart then you find the ones you want then go to a USA site and buy them from there, even with the postage it works out to be 1/2 the price of UK ones. Mine were £109 a set UK and delivered from the US (3 days) £68, no brainer really.
  24. slice replied to spannermanuk2001's topic in The Bar
    WHAT YOU WANT A "THANK YOU?" Oh never mind !
