slice
YOC Member
Everything posted by slice
  1. Sounds like clutch drag, not enough adjustment, you should probably try a new cable if it hasn't been changed from new. Or put a spacer in front of the nipple at the engine end of the cable to see if that cures the problem before you buy a new cable. worst case is worn cluth friction plates, dont go there until you have tried everything else. Does it make a noise when you pull the clutch in with it in gear? graunchy metal to metal sound if not then probably just adjustment and not plates. Should also add that this is the new member section an not the "HELP MY BIKE DONT WORK" section, say Hi and then post in workshop or people will get stroppy. Nuf said!
  2. Hi, Try this for a start, if you don't have specific torque setting then this might help. 5mm @ 3.5 to 4.5Ft lb 6mm @ 6 to 9 Ft lb 8mm @ 13 to 18 Ft lb 10mm @ 22 to 29 12mm @ 36 to 43 These are just rough guides for the torques you need, they will pinch it up just enough so that they wont vibrate loose.
  3. Check why it is leaking, it may be scoring on the upper fork leg so check them BEFORE you fit the new seals as otherwise you will just tear the new ones as well, if you have pitting to the upper leg then use wire wool (fine) and some T-CUT to get it back as near to flat as possible, DO NOT use sand/emery paper on the chrome as you will have to get them rechromed if you do, as above beware that the spring is under pressure inside the stancion leg and it will take your eye out or your ear off, do exactly as it explains in the Haynes manual and you won't go far wrong but remember to lay out the parts as you take them out so you have a reference when you rebuild it,do one at a time other wise you will mix the bits up, grease every thing as you rebuild it and make sure that the fork seals are level as you push them home, a piece of pipe that fits just inside the fork leg is best so you can knock it home without twisting it. Other than that it's quite easy just remember to take your time, finally don't foget to put oil in the forks, sounds silly but if you rush it's the obvious things you forget. Good luck.
  4. Hi Flysig, It would be nice if you said Hi in the new members section otherwise people will get grumpy with you and ignore your request for help, it's usually people who want advise and then we never hear from them again! As to your problem why don't you try an exhaust bandage, usually comes in various lengths and can be screwed into place before it sets, you will have to use an electric heat gun if you want it to work properly as they can take hours to dry otherwise. Just wrap it around the exhaust (sorry) muffler, it won't be pretty but it will be cheap.
  5. Welcome to the YOC Starky, you luck sod, you have the best roads in the world and no one on them.
  6. Welcome to the YOC LS, nice little bike just take your time and stay safe. My tax disc is on the rear of the bike behind the foot peg, left hand side cos that's what it says in the rule book, if you don't display it you WILL get nicked, you can't even use a photo copy as it's against the law (yawn) to copy an official document, what you can do is buy one of those multi bolt jobbies that take forever to undo to stop the local scrote from nicking it. Ride safe, remember Black down Blue up.
  7. slice posted a gallery image in Members Rides
  8. slice posted a gallery image in Members Rides
