Everything posted by slice
I've been a member for a while but.....
Welcome to the YOC, I always thought that the "JOTA" was only for those who had a death wish, lots of speed and brakes made from old fag packets.
Hi
Hi An welcome to the YOC, new rider then take exra care there are more muppets every bloody day who want you as a bonnet ornament!
'82 XT550 problem with revs
Ok good for you. WHAT IS IT! tell us so next time some one asks we can tell them.
tdr250 how much
Seems easy really ask a dealer!
gizmo checking in
Pretty bike, welcome gizmo.
ybr square headlight height adjust
Hi Livsey, on my XJ the Chrome surround has 2 philips screws that serve as retainers and adjusters, before adjusting them I would suggest that you whip the headlight off and oil and clean the screw threads as they are usually covered in crud and rust, other than that it's quite easy to get the lights set up. P.S. Sorry should have also said that there are 2 screws underneath the cowling that actually hold the headlamp surround in place, up underneath the lower trim
Hi Thumper, check the fuel lines first and make sure they are ok, they can get blocked same with the fuel tap filter. Pipes can collapse under pressure so if they are a bit old and knackered change them out. might I suppose be a blocked jet but then it would do it in all gears and not just 5th also check the gaskets around the carb to make sure they are not split (to much air) other than that your on your own with out more info to go on.
got started on the repair- took photos-any advice pls
Fraid so mate, should move but 5mil seems a bit loose, ok so that is one knock sorted and as you have it apart check every thing else out as well and yes decoke it while you can, don't forget to check the crank shaft as well while your at it one thing can lead to another I'm afraid.
Jimmy, try to move the con rod up and down to see how much play there is and if it moves where is it moving also look at the main bearings (crankshaft) to see if there is any play in that, there should be some small amount of movement in both but no more than a couple of thou, then look in your manual to see what it says about end float play and try to measure what you have compared to what it should be ( couple of thou is a guess) once you find out where the play is come back with the info and we will try to help out. Plus just because it sounds knocky from the back of the engine that don't mean that's where it's coming from so check both ends of the crank shaft, it might be an oil pump that is giving up the ghost and have nothing to do with the con rods or crank shaft. Good luck mate and let us know how it's going. Martin.
xj600 no spark
Simon BEFORE you buy anything check the connectors on the CDI unit, when I checked mine last year the actual connectors were rotten and although they looked ok there was actually no wire between the connectors, I had to chop them all off and redo them. Plus 2 of the leaves? that form the connection inside the plastic surround were broken off completely.
University 3rd Year Project Questionnaire of Motorbike safety
Columbos got my vote, and make the car test harder, anyone can pass it and then it's flat out in every gear, if your 17 and just passed your car test then the same as bike riders move up in power as you get better not straight onto some earth shattering monster. just in case you think I am biased I am 59 and had a car licence since I was 17 and a bike licence since I was 16 and the only time I was injured was on my bike (head full of wool female!) so DON'T ask bikers how to stay safe ask BLOODY motorists to stop using us as targets.,
hi.new to all this.but i think i am in the best place for advice.
Hi gary welcome to the YOC, someone will have a theory about your problem if you get no reply to your first query try again. Nice intro.
tight xs500 engine
Hi Gary, First things first, it would be nice to have you use the new member section for an intro BEFORE you ask for advice, it's a bit like asking a stranger for help before you have introduced yourself, no one will talk to you until they know who you are and not just here for advice and then bugger off once you get what you want. So be nice and say Hi. P.S some one will know how to help out so be patient.
a brief intro
Welcome to the YOC jimmy, Oh my what have you done? Still at least you like the bike and that's a start, don't know much about the XVS125 but they look cool. Next time you have a bevvy switch OFF the computer. Still good luck with the engine probably just needs a few parts and it will be sweet as a nut, big ends are easy to replace and you can get the crank reground so not a complete disaster, oh and thanks for giving me my first laugh of the day just off now to change my underwear.
HELLO EVERYONE!
Hi Matt and welcome to the YOC, lots of people with Aerox on here so you should get as much info as you need. Ride safe.
Coolant problems, do I need to change the head gasket
Hi, I think you may have missed the point of OGs comment, this section is to introduce your self, just like you would in the pub or on the side of the road, you wouldnt just rock up to someone and say "MY BIKES BROKE HOW DO I FIX IT?" would you? So say Hi and tell us where your from and what bike you have and then go to the "WORKSHOP" section and post your problem there, some one will know about your problem and get back to you with a fix or maybe your the first one to have this problem and so everyone will have a great time trying to work it out for you.
Hi
Hi Raj, Might be nice if you said a bit more! Where you from what you ride and any thing else that comes to mind, other than that welcome to the YOC.
Meets & greets.
Welcome jealy always nice to meet new people and talk about bikes, remember blue up black down.
Yamaha TW125 front disc torque setting
No apology necssary, like most forums it's just nice to have an introduction first, good luck with your query.
DT125 X Stolen in Bournemouth
Bad luck Billy, post a picture if you have one, some one will see it and get it back for you, hopefully the scrote who took it will die horribly!
Another new starter
Wiring is ALWAYS a horror on these bloody things, if you need help just ask, look at my xj in the garage and you will see what a mares nest they can be.
Another new starter
Hi little j, Seat should have 2 levers at the back under where the pillion sits or lock device on near side and single spring loaded lever on the same side, pull lever(s) back and lift,easy really if you know, if you want any diagrams let me know and I will copy some to you, got the original and Haynes manuals.
Hi Chambo, It would be nice if you said Hi FIRST then asked for advice (NOOB SECTION) sure someone will have what you want if you ask nicely. P.S YES it does matter how you tighten the brakes up they are the ONLY thing that stops you from dying or becoming a bonnet ornament.
01 yzf600r and durring a ride the engine will loose spark and will cut off if i let it sit for a while it will start back up
Hi, You might get more help if you sign in and introduce your self (NOOB section) tell us who you are and where your from, NOT Hi I have this bike ? and it dont work help me! Only polite really to say Hi before asking for assistance. Just like you would on the side of the road.
How to turn a drinks bottle into a solar light
Men in sheds, what will they think of next? bloody amazing.
