pcguru000
Everything posted by pcguru000
  1. Yeh really, me 2. Also- just throwing it out there... installing the indicator in the dash does cause some very SLIGHT power to sneak through, however it happens in the tail light (as this seems to be the first to get power)... when turning left the right turn signal will flicker very very faintly- you have to focus to see it. I am going to put one of these in for the turn signal indicator: http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FWLED-x.htm I am already using 3 blue leds like these for the gauges, getting a green one for the neutral light, blue for high beams, red for oil. should be set.
  2. Turns out after searching the whole bike I found a resistor that was soldered onto the circuit board of the integrated tail I have had broken free... it was jumping around and making bad connections all over... Re soldered it all back together and now its working great through and through. Just a good point to make I think- regardless of the fact that I installed front turn signals AND THEN I had problems- does not mean that the front turn signals were actually the problem... although doing something causes X - and thus undoing that something usually fixes the problem... SOMETIMES the issue comes from something entirely different.... on the opposite end of the bike.. for no damn reason. But hey- +1 to electrician and troubleshooting skills :> ALSO - going to install the indicator light in the dash again just to test that out. If it does cause 4 way blinking, I think putting a LED indicator light in should do the trick.
  3. DAMNIT! Didnt work. Not sure whats up- I got a new relay... the other one was working before... then suddenly stopped this morning... this relay is doing the same thing. First I tested to see if I could get the relay to work- its nothing... the switch seems dead... nothing changes when I switch it. Then I removed the indicator bulb from the dash- I sealed the plug with some electrical tape... still nothing- I think something else broke... what should I be lookin for? I checked fuses! They are fine. What could this be- the switch is now totally dead... should I open it up again and look to see if there is something burnt? I just dont know... how could it have changed... This is extremely annoying. lol - luckily though the advanced auto replaced the relay i bought for free... im under the impression though that the relay was not broken... again something else is shot...where should I begin the search.
  4. Absolutely genius- don't know why i didn't think of that... ive been staring at the wiring diagram for three days thinking ... there must be something goofy here.. It never occurred to me but DUH- on my 250 i had separate signal indicators- here there's just one... power sneaks through it and hits the leds on the other side... makes perfect sense... It also explains why the one side is sometimes a little bit duller- the LEDS doesn't get quite enough power... ONLY problem now is that I think i nuked the relay i just bought.... lol waiting a lot of $ on this project... but really need working signals.
  5. Alright- installed a R1 integrated tail on my seca 2- worked great for 3 weeks. Finally got a pair of led flush mounts- installed on the front... Now when I hit the switch left I get 4 ways... all lights blinking... and if I hit the switch right, the left front blinks and the right rear blinks HOW DOES THAT HAPPEN. Seriously I am at a loss now- I bought a new relay thinking perhaps it was shot... a nice new one built for LEDS ( I did have resistors in before but that seems to make no difference) Testing the power to the back lights is strange... if I disconnect the set of wires running to the tail/rear signals the whole system stops- relay stops firing etc... HOWEVER after testing the pins for the signals I found there is 6 volts on the left and right wire if switched left (turn signal switch on handle bar) and 6 volts ONLY on the right if switched right. 6 volts? Not sure if its of any consequence but the two running lights wires are just hanging not connected... sealed but not connected... could that effect it? Is there a simple way I could just avoid all of this? Wire my own setup?
  6. So this thing has been making this sound for a while, saturday however I took a friend out, rode him around for a few hours (hes after a bike lol) - noticed it got a bit worse, today I noticed the chain was very loose (67mm slack, should be 40-50) ... So friend and I tightened it to 40-42 ish - figured that would help. Did the exact oppostite... now its a serious concern... smash smash smash feeling in the left foot peg... I am guessing this is the front sprocket ... missing teeth? damaged teeth? ALSO - before AND AFTER i did the chain adjustment ... it seems to skip or jump the sprocket... Accelerating hard sometimes it the RPMS will spike as if I just grabbed the clutch really quick (assuming this means the chain is jumping the forward sprocket...) It also does it over bumps when accelerating... So, i should replace the front sprocket? anything else I should be looking for ? just wanted approval :>
  7. pcguru000 replied to mayne222's topic in Naked
    Know this list is 4 years old, but I just put a integrated tail into my 94 seca 2 that was built as an OEM fit for a new R1. The mounting hasn't changed for the tail lights in 20 years! Just two bolts.
