wize_n
  1. Greetings, I have an issue with cylinders one and four not firing on my 1886 FZX700 Fazer w/ Brand new NGK DP8EA-9 plugs. I suspected the Left Coil was bad since it is responsible for both one and four. In order to eliminate the left as a variable I swapped the Left Coil w/ the Right Coil (at the same time pulled all the plug wire caps) and connected them to their respective original sequence. (Left Bank Outside to #4 - Inside to #1) (Right Bank Inside to #3Outside to #2) The results were cylinders one and four still not firing. So I have eliminated the coil as the culprit. I am going to go change everything back to its respective place but thought I would see if anyone has any ideas were to look next or if you may know what the problem is here. Thank you in advance for your help in troubleshooting.
  2. wize_n replied to super glide's post in a topic in Yamaha Workshop
    any luck with this? I too have a 700 Fazer and am not finding a whole lot on this site for this particular bike
  3. wize_n replied to super glide's post in a topic in Yamaha Workshop
  4. wize_n replied to super glide's post in a topic in Yamaha Workshop
