Hornix
  1. Hornix replied to Doug Ellis's topic in Classics
  2. Mmm, now everybody knows I took the easy way
  3. It's been a long time since I've been here, more a reader than a writer:wink2: Last week I found a nos Jama 2-in-1 exhaust systeem for the sohc XS400. Brand new, it even came in the original cartboard box, al the parts packted in plastic bags. Costed me €100,-. I had special interest in the headpipes and the collector. The muffler was a typical eighties styled heavy metal thing with a straight cut off black endcap, not my cup of tea. But I also had a new Norton lookalike muffler laying on the shelf for my other cafeproject (SR500 big single). So I mounted this muffler and the Jama kit to the XS and this is the result: I'm very pleased with it, the grasshopper's voice dropped by a few octaves and it feels like it revvs better and runs smoother, but that can be suggestion due to the different sound. Other benefits are the weightloss of 1 muffler, the fact that I could mount this system completely stressless and the fact that I can take out the rear wheel or adjust the drivechain without having to remove the exhausts. Happy new year:thumbsup:
  4. Hornix replied to drewpy's topic in Classics
    This is how my two taps come in, think your problem is solved with a proper O-ring.
  5. finished? that's a dangerous word to say
  6. Hornix replied to drewpy's topic in Classics
    Good tip. I thought of using that tape to seal the petcocks on my Benelli tank. Did you also use a rubber ring? or just the tape? Looking forward to some pics or a vid mate
  7. I found a set of downpipes for the caferacer. Mint condition, the add said. After a few hours of cleaning and polishing they look like new. We call it "the cherry on the whipped cream" here in Holland
  8. Thanx! It is a really fun ride... http://m.youtube.com/index?desktop_uri=%2F%3Fgl%3DNL%26hl%3Dnl&hl=nl&gl=NL#/watch?v=-Jdf7jlKc10 And when the weather is bad, I give the sr500 some attention any ideas about the colours? I was thinking of a silvergrey frame and dark tankcolour.... Cheers
  9. The grasshopper is upgraded with Newtronic electronic ignition. Runs very good and although it was an easy starter, the XS starts even better now. There is also a new problem I have to fix: replace the starter motor. It makes a realy awfull noise now. I think the internal gears are worn or broken. The noise comes from under the starter motor cover so I hope the starter clutch is OK.... the camera had some troubles to focus on the disco light
  10. Thanx for the compliment! But imho anyone can do this. And don't forget that I sold my '97 ZRX1100 for this project. So the budget wasn't that big a deal
  11. Hi, sorry for the delay For pictures you can look at my topic at the Dutch Motor Forum. http://www.motor-forum.nl/forum/list_messages/242933/Hornix-Sushi-Sjeezers-Yamaha-XS400-SR500-1.html Cheers!
  12. Hornix replied to Moretto's topic in Classics
    Drink the bottle, sober up, put in the cork, ride on!!
  13. Is it possible to post here a simple colored wiring-diagram of the ignition swab? I ordered the pickup and cdi and also found some matching coils in Germany (they were intruduced at the XS400SG and were also used on the dohc models. I figure that they are high output models?). How did it work out? Better handling/gas respons? Stable setup? Thanx!
  14. Hornix replied to panzer's topic in Classics
    Sounds that you don't have the right cable. I think the inner cable is to short. When you release the throttle, do you hear a metal tick? (it's the carb turning arm hitting it's idle adjustment screw). Do as Drewpy said, if it idles normal you have the answer. And put the airscrews back to the original position or you'll get lost in a dark nasty place called carbmessedup-city on planet Mikuni.
  15. Hornix replied to micha's topic in Classics
    Will we ever see Micha again?? Or is he busy adjusting the ignition, German style?
