ashaq54
  1. Hi, I am writing from Bangladesh. I am having some trouble with my 2500+ KM old Yamaha YZF R15. I have also taken my bike to the local Yamaha Dealership/Service Center. However, they could not pinpoint the problem. Therefore, I am seeking for some opinion/insight from your end. Below goes the symptoms I face with my bike: a. Idle RPM is wrong. It fell to the range of 1200-1400. Had it adjusted back to 1300-1500, but, still during the first 5-7 minutes it fluctuates a bit. b. Bike stalls while decelerating, pulling in the clutch..no matter if i downshift at the same time or not. c. This happens mostly in case of high speed runs, if i pull in the clutch and release the throttle totally, the RPM drops from say,7000 RPM to 1.5K for a sec and then drops to zero, stalling the engine. d. After the engine has stalled, if I release the clutch while the bike is still rolling, the engine fires up again with a slight jerk. e. While slowing down, if i keep the throttle a bit open and pull-in the clutch, the engine keeps running. f. In neutral the bike idles fine at around 1300-1600 RPM g.This problem mainly occurs during the first 10-15 minutes of riding. After that it somehow disappears or occurs much less frequently. Could you please point-out some factors that might cause this trouble, which will help me to solve this through the help of the mechnics.
