oldmanstoner
Everything posted by oldmanstoner
  1. Thankyou i have ordered the part can i still ride the bike if the sael is damaged
  2. Hi guys can anyone please tell me how to change water pump seal as mine is buggered thank any help will do
  3. Hi guys thanks for all the help. I have a slight problem when the bike is in netural or have the clutch in the bike revs fine, but when I ride it seems as thoutgh the bike is missing, but not all the time and some time the reves drop and if you open the throttle they pick up again if you rev it a few times. I think it is a feuling problem so I took off the carb too see if any dirt got in and check the jets when I blew on them they didnt seem blocked and sometimes back fires ____________________
  4. -------------------------------------------------------------------------------- Hi guys thanks for all the help. I have a slight problem when the bike is in netural or have the clutch in the bike revs fine, but when I ride it seems as thoutgh the bike is missing, but not all the time and some time the reves drop and if you open the throttle they pick up again if you rev it a few times. I think it is a feuling problem so I took off the carb too see if any dirt got in and check the jets when I blew on them they didnt seem blocked ____________________
  5. I unscrewed the cable that goes to the carb from the accelerarer cable there is a long groove that runs up the side of the slide in the carb with a needled attatched to it. I put that long groove on the same side as the air box and then scrwed it back on. Cleaned the plug and started fine.tym to ride
  6. Thanks changed the side and it now works thank you
  7. Sorry meant the base gasket.
  8. My apologies. Iam a male and live in South Africa. When I put the head back on, I made sure that it was clean I sprayed DW40 but that didnt help. Any other suggestions would help thanks
  9. Hi guys im glad i found this site was readin a few topics and then joined i blew my head gasket on my dt and replaced it i stripped the whole bike down and rebuilt it but when i start it it just revs what could that be the slide in the carb that doesnt close because it is the wrong way or could it be something els and what spark plug should i use and when i tried to start it again i wont start i started it a few time while reving high and turned it off but it wont start again
