Prichard XT
Everything posted by Prichard XT
  1. XT125r 75mph 0 - 60 not sure but it aint no 600 a damn long strech of road
  2. Prichard XT replied to ldeniro's topic in Yamaha Workshop
    that aftermarket speedo looks like a good option worth a try
  3. Prichard XT replied to ldeniro's topic in Yamaha Workshop
    turned out that wasnt the problem for me this time checked the fuse battery and ground conections still nothing giveing a full system check ove the next couple of day can guarentee its a connection issue let ya know if i can pin point the problem give a proper solution with out spendin hundreds
  4. Prichard XT replied to ldeniro's topic in Yamaha Workshop
    Its a design fault which yam dealers will fix within warrenty mines been rewired 3 times and the last time i rewired it, it wasnt the wirin loom it was the back of the key ignition the three contact plates were loose due the springs behind them lossin compression simple fix was to clean the contacts and strech the springs by 4 - 5 mm put back togethe in the right combo and it all worked iv got the same problem again dose only the green head light square and indicator green square work good luck let us know if ya find the fault
  5. best top end i ever got was 75 mph that took some nice piece of road on a decline but its had alot of tweeking sound like a monster now
  6. Im About To Buy New Sprockets Would It Be Worth Going Up From 14 Teeth To 16 On The Engine?
