Dom660
  1. Hi thanks for that, though you may have a different hub to mine, my DT175 is a 1975 it has a symetrical hub, I think the later DT175 MX had a offset hub. Cheers
  2. Hi Guys I'm looking at lacing a new set of wheels for my 1975 DT 175, I have a couple of spokes left on my 21" front wheel to measure, though if possible I'd like to check other bikes of the same year and wheel size to confirm mine is correct. I currently have a spoke length of 225mm from the spoke end to the spoke bend. 230mm complete length. Many thanks
  3. oakley Spin in Guernsey Channel Islands 2012
  4. Not a bad idea on using copper first, though I think I might have found someone locally who might be able to make some pipes up for me, I'll keep you posted on the progress. Cheers.
  5. I contacted Redmax speed shop about custom exhausts, but the same as Harris they need the bike to construct the exhaust, the problem for me I live in Guernsey a small Island in the English Channel. I might buy a few bits of pre bent tube to experiment with, I would like to as much work as I can on this project.
  6. Hi has any body had any experiance in bending 38mm Stainless tube for a custom exhausts, I've watched a few videos on youtube, though i've not found many home made pipes, most guys are in professional workshops using expensive machines. I've found some sections of pre bent tube, but have visions of it looking like spaghetti junction. I'm looking to build a set of down pipes for an XS 400 that has the twin high side exhaust "Flat track style" and then use some Megaphone silencers as tailpipes.
  7. Yes quite deep pits, it looks like the casing had a weld repair along time ago, but I've only just noticed it after having the casings blasted, I may have to consider re painting them or try and find replacements on Ebay.
  8. Hi has anybody got any experiance on repairing small areas of pitting on alloy engine casings? Thanks.
  9. Thanks for the responses Guys. I'll post some pics up later. Cheers
  10. Hi, has anybody have experiance with dished front sprockets? I'm working on a XS400, Ive fitted a different swing arm to allow for 150 rear tyre on Talon wheels. I need about 8-10mm on the front sprocket to allow for the chain alignment. Thanks
  11. Dom660 posted a topic in Classics
    Hi, I might be looking to sell my DT 100, i think its a 1979 model in very good condition, Ive looked through Ebay but never seem to find any. Does any body have any ideas of prices?
  12. Dom660 replied to Dom660's topic in Naked
    Thanks very much for your reply, I'm looking into fitting a modern front end on to my old XS400, so that has helped alot. Cheers
  13. Dom660 posted a topic in Naked
    Hi, could anyone tell me what length and diameter the forks are for a XJ 600 diversion ? Thanks
  14. Dom660 replied to Dom660's topic in Classics
    No I'm with Hornix, it feels exactly as he described as if something is physically jamming and stopping the bike from moving backwards, its not gradual its immediate. There isn't a kickstart on there at the moment so I'm not sure on that scenario.
  15. Hi, the DT100 was pure fluke, I literally stumbled across it while going to do some work on my DT175, the guy in the next lockup had recently bought it , so after a quick chat and a few quid it was mine.
