Licks
  1. Yeah, i'll be taking the exhaust off anyways (had a slight spill in the rain yesterday) and it's bent one of the brackets that hold the exhaust on (No other damage i could see from just looking though O.O) Haa, then i'll take whatever pictures I can
  2. I have grabbed a 2 piece of ebay I'm pretty sure it's the same as the one that's already fitted but i'll take some pics while i've got it apart if you like Oh, anything else I should do while i'm fitting the PV? Cleaning anything up or checking anything? Thanks very much for the help guys
  3. Thanks very much for your help. Have the power valves changed much over the years? Or could I salvage one from a newer model?
  4. Yeah, sorry. You are quite right, it's the diamond bit on the valve that sits in the back of the pulley that has broke. Does this mean replacing the whole valve then? I haven't really taken much of it apart, i just noticed that the diamond shaped bit of aluminum stayed with the pulley when i removed it :/
  5. Hey guys I recently bought a 1998 DT, but giving it a good once over i've noticed that the powervalve pulley has been broken (The small diamond shaped piece has completely snapped) and this is causing it to slip when it opens. Just wondering if there's anywhere i could get a replacement? Pattern part or a used part is fine, just want to get the thing running well. Thanks
