quickchuck
  1. quickchuck posted a topic in The Bar
    Found this forum while trying to figure out why my YammaGamma is smoking. Well that seems to be fixed but it wouldnt start this morning and dripped a little fuel. Will look at that tonite. Done 400km since getting it together and passing French moto test(arrrg). Its a rocket ship above 7k usually starts 3rd kick cold. 86YPVS from Italy cheap. A bit loud with those Figaroli pipes and Stan's stage 2. Its been like a video game getting this far, get stuck, look online(cheats) fix the problem, next!!! And some of the problems delt with so far: -wouldnt idle: carb slides were in backwards(duh) -Clutch wouldnt disengage: removed and freed plates -Exhaust spitting oil at flange: put in viton seals -Clutch slipping at 7k+: New plates + 3 springs + box oil -Excesive smoke: adjusted oil pump
  2. I too have fresh rebuild YPVS on Stan's stage 2. Its got 400miles and really screams, gone up to 8000rpm. But its a bit smokey. Am measuring oil/fuel consumption and its at 5% = 20:1. Will double check the cable adjustment but I figure it should be 30:1 = 3%??? And now Im worrying about this small end risk... What to do?
