akamor
  1. Hello all, I might be buying a 1981 XJ750 Seca. How is the parts availability on these motorcycles? Thanks, Adam
  2. Hello all, I have the option to buy a 1982 Yamaha Virago. The bike is currently not running and will need some work. Most likely just carburetor rebuild, but who knows, it could need more. I am new to this bike (my last yamaha was a 1980 XS400 which I loved), what is the availability of parts? Are they easy to come by? Are they relatively cheap? This bike was made well before I was born. What was its reputation for reliabilty and quality? Thanks, Adam
  3. That sounds good. I did that tonight but I am still having problems with the bike. The darn thing wont idle without a choke. I think I am going to move on and reclean the carburetor and recheck for vacuum leaks. Thanks, Adam
  4. Hello All, I have a general question about valve clearances. On a four cylinder engine you must rotate the crankshaft 360 degrees between measuring 'partner valves'. When I say 'partner valves' I mean something like Intake on Cyliner 1 and Intake on Cylinder 4. Or the exhaust on cylinder 2 and the intake on cylinder 3. My understanding is that the camshaft lobes are 180 degrees apart on these 'partner valves', does this mean that a 360 degree turn of the crankshaft corresponds to a 180 degree turn on the camshaft? This is a 4-stroke engine, btw. Also, how do you verify that you are at TDC of cylinder 1? Is it when the cylinder is at its highest position. I was checking by sticking a screw driver down the spark plug hole and moving the back wheel in 5th geer. When the screw driver was sticking out the most (i.e. the cylinder was at its highest) I assumed it was TDC. Also, if cylinder 1 is at TDC does this mean cylinder 4 is at TDC? Thanks as always, Adam
  5. Thanks. That sounds like a great place to start. 1) I have already tuned/synced the carburetors, so that is out of the way. 2) The valves are definitely on my to-do list, I just need to muster the courage. 3) In regards to timing, however. According to my manual my model (1980 XS400G) has transistorized timing as opposed to break point ignition, which means timing need only be checked if the unit is removed from the motorcycle, which has not happened. What is your opinion on this matter? 4) I do not believe fuel delivery to be the problem. I should have given more details when I first made this post. Let me explain further. After the bike has warmed up it ONLY has trouble going up hills. If I start at the bottom of the hill I cannot get up the hill unless I keep the rpms high. I have no problems on flat ground. Do you still believe it could be a fuel delivery problem? The mechanic that sold me the bike says it could be an electrical failing that only manifests itself once it becomes hot. What is your opinion on this statement? Thanks, Adam
  6. akamor replied to bznchris's topic in Classics
    Your bike looks awesome. May I ask where you found your exhaust piece? Adam
  7. Hello All, My 1980 XS400 starts up and runs great for the first 15 minutes of driving. After that the bike will randomly lose power when in motion and will sputter and eventually die unless I put the clutch in and come to a stop. The problem is especially bad when going up hill. Since it only happens after the bike is warmed up I suspect an electrical failing because I figure the electrical components are more sensitive to heat. Does anyone know where I can start on this? My initial thought is something is wrong with the timing. Thanks, Adam
  8. akamor replied to akamor's topic in Yamaha Workshop
    Thanks. I did as you said and traced all of the connections and made sure everything was hooked up properly. After fixing a couple of connections everything works great. Adam
  9. akamor replied to akamor's topic in Yamaha Workshop
    It is both front and back. I am not sure if it is the left or right side because I am sure at some point I messed up the wiring. However, it is only 1 in the front and 1 in the back. Adam
  10. akamor posted a topic in Yamaha Workshop
    Hello All, I am working on the electrical system on my 1980 XS400. I am trying to figure out the problem with my turn signals. I have several questions for someone with a working XS400. 1) When I turn the key should the turn signals light up? Currently when the key is in the ignition but the engine is NOT on my turn signals are on. When the bike is running the turn signals remain on continuously and using the turn signal control on the handlebar has no effect? Is this normal. 2) Only 2 of my turn signals light up. The other two are off, regardless of whether or not the engine is on/off and regardless of what I am doing with the turn signal controls. Any advice on where to begin looking would be appreciated. Thanks, Adam
  11. Could you explain what you mean in more detail? One end of the ground wire should attach to the frame. Where does hte other end attach to? Thanks, Adam
  12. Thanks for the quick response. Regarding my other questions: Why does the manual state the regulator is mechanical? Is it possible I am missing the screw? Adam
  13. Hello All, I am trying to figure out why my battery is not charging on my 1980 XS400. I have tested the alternator and rectifier according to the manuals specifications and everything seems okay. I am having some trouble testing the voltage regulator. According to the technician manual the regulator should be mechanical with some sort of adjusting screw somewhere on the body. My regulator does not seem to have an adjusting screw and I do not believe it is mechanical. It looks like the part in this ebay auction: http://compare.ebay.com/like/120578199689?ltyp=AllFixedPriceItemTypes&rvr_id=&crlp=1_263602_263632&UA=L*F%3F&GUID=831f21641280a0e205467ac6ff344981&itemid=120578199689&ff4=263602_263632 How do I test this unit? Can I follow the instructions in the manual and just ignore the part about the adjusting screw? If it is actually a semiconductor and not mechanical I do not believe it makes sense to measure resistance between different leads. Also, the replacement I have found for the bike are quite expensive. I have a lot of experience in electronics and I was wondering if I can just make my own voltage regulator unit. Does anyone know the specificiations? Thanks, Adam
  14. Hello All, Thanks in part to everyone on this forum my 1980 XS400 is running strong. Now that I have the mechanical issues figured out I need to work on the electrical system. The biggest problem is that after riding the bike for only about 30 minutes the batter begins to die and it becomes hard to start with the electric start. I am fairly confident the issue lies in the alternator. When I put the engine at 2000 rpm and measure the voltage across the battery terminals I typically see it jump to about 12.8 volts, but never higher. To me, this implies that the alternator is not performing properly. What steps should I take to troubleshoot the alternator? Thanks, Adam
  15. Hello All, I have a general question about interchangeable motorcycle parts. If I go to a website like www.bikebandit.com and look in their OEM parts sections for the same part from two different bikes and they have the same part number does this mean they are interchangeable? What is a general method for checking part interchangeability? I need to buy a new carburetor on Ebay but it is for a different year motorcycle. According to www.bikebandit.com they have the same part number (and same cost). Does this ensure compatability? Thanks as always. Adam
