Exjay
Everything posted by Exjay
  1. did you ever find out?? I want to take my forks apart and the haynes manual says to make a home made tool with the "correct" size bolt as a hex drive. it does not say what size the hex is in the bottom of the stanchions is? and it is not the easiest thing to measure. Phil
  2. Many thanks, sorry for delay in replying, Phil
  3. Am rebuilding a pre divi XJ600. Not got the engine running yet, I am sorting out the loom and the electrics. What I need to know is should the oil light come on when you first switch the ignition on? or is it only when the oil level falls? I do not want to remove and check too much stuff if it is working correctly. Apart from the neutral light, is there any indication that the ignition is switched on? Phil
