raptor
Everything posted by raptor
  1. hi all if the ride goes on let us no , 5 from bath area would meat up with you all thanks
  2. if you still not sorted this fault out at the back of the loom theres three plugs you need to re,wire ,this is meant to use jumper plugs ,when thay fitted the alarm thay would have removed them you should not be able to get this info for re wireing them but your yamaha dealer will no them you will have to book it in. had the same fault with mine , hope that helps
  3. Can anybody help i have a 1999 r1 which will cut out when ridding can be fine for 500 miles then can cut out will start back up fine and be fine again for weeks. have checked most things unpluged alarm syetem but still did it so put that back on , so any help would be good bike shop i use have checked clucth swicth side stand swicth,coils,plugs,set up carbs its just like you hit the kill swicth off when ridding ????????? thanks.
