Seca400Monster
  1. Thanks everybody for all the help, signals are working great.
  2. Does anyone know where I would find the flasher relay and where it is located on the bike?
  3. Thank you very much for your help, I will post some pictures of some of the wiring and what I think is the relay. Thanks Jimmy
  4. I am trying install new front and rear LED turn signals and I am having a lot of trouble finding where to connect them. I have a load equalizer and a full front and rear turn signal kit. The wiring going to the rear (from the bike) is one brown wire and one green wire, from the turn signals it is one red and one black (for both). I am not sure if the two red wires connect with the green and brown wires and both black wires are for ground. On the front I have only been able to find one wire that I think is a signal wire. I have taken apart the turn signal switch and everything works. If anyone knows anything about this, or turn signal wiring at all, your help would be greatly appreciated. Thanks Jimmy
  5. I am trying install new front and rear LED turn signals and I am having a lot of trouble finding where to connect them. I have a load equalizer and a full front and rear turn signal kit. The wiring going to the rear (from the bike) is one brown wire and one green wire, from the turn signals it is one red and one black (for both). I am not sure if the two red wires connect with the green and brown wires and both black wires are for ground. On the front I have only been able to find one wire that I think is a signal wire. I have taken apart the turn signal switch and everything works. If anyone knows anything about this, or turn signal wiring at all, your help would be greatly appreciated. Thanks Jimmy
