tudor55
  1. There is a diode under the seat that controls the voltage to your battery if its weak or gone it will not charge!
  2. tudor55 posted a topic in Naked
    Hey got a problem with my bike it will back fire when i let off the throttle and i have notice that is will misfire almost at 4000 rpm ,where should i start the carbs ,change coil already and plugs still the same! I have clean the carbs every year pretty much and for some reason it gets better but not solve totally. Voltage is 14.5 at 3000rpm so that's good ,i did however burn up the diode and replace it with a new one and it burn also! but i got one to work maybe my current to low or to high! I'm lost and manual doesn't help all to much .
