Neos yn50 won't rev
Yep I took exhaust to check and all seems fine and replaced with new gaskit. Thanks Dave
Neos yn50 won't rev
Yep 2 stroke twist an go yes fuel good I sucked the vac pipe and fuel poured out of the other pipe also took main fuel feed pipe to carb off kicked bike over and fuel came out ok. Thanks Dave
Neos yn50 won't rev
Ok great I will try that thanks
Neos yn50 won't rev
Air ? how do I check air ? Thanks Dave
Neos yn50 won't rev
Hi all My son has got a little Neos yn50 and all was running fine until it stalled for no reason, he said it was hard to start again and then it had no power. when I had a look at it it would rev but then cut out, riding it it wouldn't go over 15 mph. I have checked fuel is getting to the carb and have stipped the carb right down and cleaned all the jets, put a new plug in, I have done a omhs test on the coil and it seems fine, checked ht lead and cap and am now at a loss, so have any of you guys any ideas what to look at next ? Many Thanks in advance Dave
- Semi Sin oil or not ?
Hi all I have looked but can't seem to find any info on this. I have just picked up a Virago 535 1997 and want to service it, in the hand book it say's use sae 20w40 or sae 10w30 api se or sf I would like to use semi sin as have been told this is better for the engine but will the wet clutch slip ? so in short can I use semi sin or stick with the hand book ? Hope all this makes sense Many thanks Dave
- Yeeeeeeeeee Passed
Yeeeeeeeeee Passed
Hi all just passed mod 2 and loose on the road at last ) Just picked up new bike Yamaha virago 535 1997 with 3k on it, been in a garage for 10 years unmoved. rode it 120 miles home with no problems. service in the morning then off for a nice long ride. Dave
- Taking Test
Taking Test
Hi all 1st post Well after many years have now decided to do my bike test. Do I need to go to a training school or can I book my test myself and just do it ? I have been riding for a while now and have watched many videos of the mod 1 and 2 and I feel I am ready for the test. I want to take it on my ybr 125 custom and then get a 400cc, then after 2 years go bigger again. Hope all this makes sence Many Thanks Dave
Dave.42
Joined
Last visited
