Everything posted by Alan m
		partsts cross ref
		i was fooling around a couple o weeks ago and found a site that gave parts listing that were common to different bikes ie clutch plates fro my xtz were the same as xt 600 blah blah and so on bear ing for this was same as this bike and gave a list of maybe 10 diffedrent bikes that used the same parts but cant find the site for love nor money any body and ideas would be very habndy to have a link on here for it as the russian on is a bit bogey
		Starting noises
		starter clutch is behind the flywheel the chain from the started should run down to it a good tip wpould be to disconnect the chain from the starter and turn it over and see if there is any grinding from the starter bearings but to be honest a 73 motor will prob not have had the clutch bearing done in a while if at all if you don't feel comfortable doing it get a mate with the know how to do it and show you the ropes do it once and do it right do it twice and waste your night sounds taccy i know but when you do it right you will fell better for it
		Starting noises
		sounds like the starter motor clutch bearing is worn its a one way bearing when you engage the starter it turns the bearing which spins out and turns the motor over when the engine fires it disengages havin the same trouble with my ride trouble is its a 300 euro fix for mine 73 tx should be fairly cheap enough to sort seems to a common prob on the tx
		How the Irish Really Learned To Dance
		ah ya see if that were true irishman we would just kick the door down or go in the womens bogs
		92 xtz 660 tenere
		full weeks work done on the bike and its running sweet
		92 xtz 660 tenere
		days work done and it went fine no prob job sorted touch wood looking fior a right hand side panel if you know of one lying around any other tips for the tenere appreciated would like to go for the later twin headlight set up dont know if it will fit ? cheers for the info any way it would be good to get a list of compatable parts if you know any fazer 600 generator coil fits for a start you will need the xtz pick up honda cb 500 reg/rec aswell red to red earth to green there are 2 red and two green on the cb 500 any one will do as they are in the same block three other colors to white from the loom
		92 xtz 660 tenere
		well its all back together and sounds sweeet a lot quieter than before replaced the generator coil aswell while i weas at it used one from a fazer 600 but the pick up would not fire so swapped it for the original pickup gonna take it out tomorrow for work a days dispatching will give it a proper test rick the parts were all new superceded parts the pic shows the difference in the color between the new and the old left are the new ones
		DT 175 help
		if the head was blowing you would hear a slight whistling sound as you try to kick it over , if you lift the head look at the gasket and the gasket face of the head a leak will show as a darker color on the metal and on the gasket
		DT 175 help
		if the carb is overflowing it is prob the float needle is either worn or there is dirt stopping it from closing ,make sure its clear and check for signs of wear on the rubber tip of the needle when puttin it back make sure the float is closing properly A good trick is to leave the bowl off the carb connect it to a fuel source[ hold it level as it would be in the bike] hold the float closed and turn on the fuel for a second just enough to let juice through, if it flows through with the float closed you have a needle problem if not let you float free and close it again with fuel running through and see if it stops again if it still stops well you have another problem be careful no sparks etc the only way in to a carb is through the float chamber so this has to be were to start looking from probs hope this helps
		92 xtz 660 tenere
		what are ya looking for im going out to them on fri to collect my parts i can check with them part numbers would be handy i can get prices and have them for ya fri evening
		92 xtz 660 tenere
		danfay down in sallynoggin when i said direct i meant i bought off them direct shops will charge ya for the privilage dont ya know good lads out there which wee island you from any were near letter kenny good mate o mine hails from up there have his beemer in me garden doin a bit o work on it for him
		92 xtz 660 tenere
		ordered the parts today its a first for rip off ireland but the parts came in at 43 euro including vat ,a hell of a lot cheaper than i thought they would be their genuine yam parts aswell got them from the irish yam distributor direct will have them in 48 hrs from holland . oem wanted to charge me 30 euro for a courier can you enlighten me about the dots ? i figured the shafts will have to be lined up will have to read my manual thanks for all the info
		92 xtz 660 tenere
		stripped the clutch cover off today wood ruff key was split in two on the balance shaft and the washers were worn down luckily the key ways are fine but new parts are a priority now the plus side is its not the crank so no new motor needed i hope see pics completly split lucky it did not seize badly worn away
		92 xtz 660 tenere
		cheer the part nums would be great is it an engine split job or can i get to the prob easy enough ?
		92 xtz 660 tenere
		cmon lads must be someone knows something?
		92 xtz 660 tenere
		the crank on my 1992 tenere ENGINE NUMBER 3YF 006~~ has decided it wants to make lot of hammering noise i can get hold of a lump with a good crank from my local breakers but it came from the mz version of the tenere my top end is perfect so i want to transfer my good top end to the yam/mz bottom he has gone over it and matched it up to a knackered lump from a 92 and reckons it look and fits but i need a nod from some one in the know before i hand over my cash so over to any one who knows if it will fit with my good top end and all the gubblins hoses etc any help appreciated
		xtz 660 fairing parts
		ok first for some reason i cant post in the wanted section so if anyone wants to bump this feel free or if a mod wants to open the wanted section for me thats even better thanks in advance looking for the protector piece purple if poss but if not no probs for the 92 xtz 660 3yf[ prt num 3yf-834w-10 ] and the plastic clock surround that goes over the protectors [prt num 3yf 2837m-oo] once again thanks
- no spark
		no spark
		me missus would prob say the same well i got it running so hope fully i have solved it task was off and it cut out but gonna start puttin back together today heading off for a week tomorrow so hoping to get it sorted the saga will continue
		no spark
		have 3 cdi's made up good one today got spark its not over heating which is plus not a great spark thgough i was reading another site and got a tip clear off all the anti vibe glue seemingly overtime it acts as a conductor so i cleaned it all up and lo and behold its sparking not great but its a start so the thinking is it might be a condenser some them became loose as i got rid of the glue so i might change one or 2 loose ones time will tell ,
		no spark
		first i have tried a search and all i get is this One or all of your search keywords were below 3 characters or you searched for words which are not allowed, such as 'html', 'img', etc, please increase the length of these search keywords or choose different keywords. so please don't tell me to search as its been already discused i cant as it keeps giving me the same answer ??????????????????? ok rant over i have changed the re/rec tried 3 different cdi's there is power going to the coil as i have checked the red wire/striped wire every once in a while i will get a slight tickle if i touch the plug wire but nothing to stop my heart i cant keep or can afford to buy more cdi's i have also checked the loom stripped it back and checked all wires and conections no probs or dodgy earths fused wire etc the last cdi got hot at the 3 wire pin and the red battery wire got hot as did the rec/reg so i dumped that one for a later model one no more hot wires or reg but the cdi heated up ? i have a spare pickup /gen coil could this be the problem shouild i change my one out and try it ? so i am stuck and cant get a workshop manual for the xtz 660 tenere is there any way of checking the cdi with multimeter can't find a manual with the proper reading so if any body knows were or how to do it please let me know again thanks be patient im new to the xtz range thanks in advance for all your wonder full help and solutions maz
		xtz 660 ? to buy or not o buy
		hi lads im supposed to be picking up an xtz 660 1992 later on today but before i commit is there any real probs apart from the cdi is missing off the one i am getting its in good nick and was running its bin lying up fer a yr and the black box is in the wind from the checking iv been doing the tdm will fit it but affects the bottom end ? is the cdi a common problem ? seems to be a lot written about the cdi ?and are the 660 and 750s part common to each other i know my way around a bike but its my first tenere and im not arrogant enought to pretend i know it all so any help appreciated also if any one has a pulsar coil or knows were i can get good second hand or even a new set please post local yamaha want 500 euro for a cdi????? looks likethe buy is on hold for a week gives me a chance to check the marque out any feed back welcome
_33963e.png)
    _83bc35.png)
