Kyle, this fault is common with running the chain too tight and to replace the bearing will inevitably need you to split the engine.
To prevent this, I have always run my chain slightly looser than spec ( 1/2 in either way with load on seat)
Hope this helps, even if it's not the answer you wanted!
