Stormin stu
  1. Hi, Have you checked your float height? Many times I get bikes that the float height is set way too low. A lot of times people will go for the floats if the bike starts to spew gas from the carb when it's just time to clean it up. The bike will run ok untill there is a high demand for fuel, the bowl gets dry before anymore fuel can flow into the carb and it can show up as simply as a lean condition at hard accel or wide open throttle position to complete motor stall depending on how far out of whack they are? Just a thought, stu
  2. Hello everybody! I have a question about magneto compatibility. I have a 72 LT2 with a fried mag. it's a 6v system with three coils and 4 wires + neutral sw. wire. Does anybody know if there is another yamaha model that uses this same mag? yamaha parts shows nothing on the LT2 except crankcase a fish. looking at other models iv'e found varying part no's some with two coils some with three. I assume the three coil models are 6v and the two coil are 12v. anyone have a wiring diagram or manual for an LT2 or 3? I think maybe the gt80 would work but would nessesitate swapping bulbs to 12v? Ive had no luck locating a replacement and would rather not spend the $200 on a rewind if there's a compatable part available for a more attracive price. thanks stu
  3. Stormin stu replied to YG-one's topic in Classics
