misteroe
Everything posted by misteroe
  1. Thanks Houghmade - will do the checks on gaskets as I gradually strip the engine down to find the fault Bit of an update though - thought I'd check the compression again to check the 'poor running' problem. The results were intersting: Right cylinder 140psi just as it should be according to the manual. Left cylinder 105psi way off what it should be!! I rechecked both cylinders, twice, with the same result. There's loads of questions I could ask but I'll stick to topic, so ..... Could the low compression on the left cylinder contribute to, or even cause, the oil warning light to stay on? Just trying to narrow down the problem, anyone any thoughts?
  2. I have recently rebuilt from top to bottom a Yam XS500C, 1977 vintage. The engine was totally stripped down and rebuilt step by step - I'd better point out here that I'm not a mechanic, I just take my time, follow the books and use a bit of 'common' The bike started on second push of the starter button - it's not running right , but I can work on the carbs and timing later. The major problem is that the oil pressure light stays on when running - Not good!! The 'book' says turn off the engine immediately, trace and rectify the fault - that's it I've tested the pressure switch - remove, compressed air blown in, multimeter to check circuit breaks when under pressure - all OK The correct amount of oil had been added (about 4ltrs with a dry engine) So what do I do next?? I am presuming the oil pump is working as the tacho drive works - they are both driven by the same shaft - and checking the pump is a last resort as the engine has to be totally stripped down to remove it - and I did check that all was working when I assembled the engine. So, where do I start as a 'first resort' ????? Can anyone help and point me in the right direction, things to look for or check?? Top and bottom of it is - the last thing I want to do is remove the engine - so what can I do before I have to do the last thing I want to do - are you following this Hope someone can help me please
  3. Harry - in this day and age what did you expect!! The Web-site at the end of your message isn't exactly informative. You've given no details of yourself in the profile and all we know is that you have a 'client' wanting you to find someone to do the work 99.9% of us are a 'serious group' of people but, as the name suggests - this is the Yamaha 'Owners' Club not a restoration factory I'm sure that anyone in the group will contact you if they are interested in your offer and, if it's genuine, good luck to them. In my view, if something sounds too good to be true - it usually is!! And, if you are a spammer you don't need all 99.9% of us 'serious group' members to tell you what and where to go
  4. misteroe replied to bunzi999's topic in The Bar
    Hi Steve You could try contacting: skidmarx I had the top fairing of my FZ750 damaged and they supplied me with a replacement at a fraction of the cost (£120) of a genuine yamaha part (£350). You will have to paint it or apply graphics but it's still a cheaper alternative. Try the bike painters in your area for panels - I've just been to a guy in Hull and he had racks of panels for 'just in case' repairs - worth a try perhaps? Cheers, Andy
