FathomYourFears
  1. Unfortunetly gas/petrol still passes through. Any ideas on what the problem is?
  2. UPDATE: I refurbished the petcock. I replaced all the part and reassembled. When in the "ON" position, my petcock drips. Is this normal?
  3. I was out working on it and I missplaced he key and can't seem to find it for the life of me. Now I need a new ignition lock and key and tank lock and key. Any ideas?
  4. You got rid of the stock one and put a different petcock in? Or did you put a manual one in-line?
  5. Arrggg. Thanks. This means I need a petcock rebuild kit. I was washing my bike today and I noticed my oil in the sight-glass went up above the glass. So I went to drain it and it smelt horribly of gasoline. How difficult is the rebuild? Any good place to get the kit? Thank You.
  6. I have a 1981 XS400 special. As you may know, the petcock is a vacuum-fed when in the on position and when in the prime position it dumps fuel into the carbs through gravity. My question is: when it is set to reserve, is it still vacuum-fed? or does it switch to gravity fed like prime position? Thank You.
