Mikey B
  1. Mikey B replied to Mikey B's topic in Yamaha Workshop
    thanks so much for your help guys. Its something i'd not encountered before, but i appreciate your help. Safe riding, Mikey. Cheers YamHead.
  2. Mikey B posted a topic in Yamaha Workshop
    my xj 550 dipped headlight is flickering and dim at idle and low rpm, but if i blip the throttle the light brightens til the revs drop off. same happens on the motorway. the main beam is unaffected and is bright across the entire rpm range. also, i have no headlight on turning on the ignition, until i have started the engine... is this normal? the tail/brake lights are unaffected as are indicators and dash lights.... any help on this would be greatly appreciated
  3. I own an '82 xj 550. Its running sweet since i refurbed the carbs, but the other night I was riding home and noticed the headlight was dimming out on me at low rpm. if i blip the throttle the headlight brightens up but as the rpm drops off so does the light. however, it also happened at 90mph which was a bit hairy to say the least. any ideas what could cause this? i've had a little dig around but the temp. in canada has plummited and its now snowing so i want to avoid hours of fault finding. any help would be greatly appreciated, thanks.
  4. Awesome, I'll be passing that on to the wench.....
