radian yx600
  1. i have a 86 yx600. ran great. i have to rebuild the carbs and then it will run great again. FYI the float valves on these like to wear and then they leak gas out of the carbs and into the oil.
  2. hello i have an 86 radian yx600. it has sat for awhile. i can get it started but if i rev on it really hard and fast it sputters out (kind of like it is choking out). i have checked the valve clearance, timing, and compression. so my thought is the carb.. i took them apart and everything looked fine. also from time to time the carbs will just seep out fuel from an overflow valve. please help if you can, basically i have ran out of things to try and i really dont want to have to get rid of this classic speed demon -kyle
