c_realica
  1. you guys have been so much help! i took the carb out and cleaned it up. it runs 100 times better!!! on another note, does the oil light only turn on because of the oil pressure?
  2. ok im gonna try and put a new carb in. ill get back with results. thanks for imput. what is the difference between the mx and lc?
  3. ok so i just got a 1982 dt 125 i've never owned a dirt bike before. it starts fine. once i try to drive it i cant give it too much gas (almost none) or it will bog out and die unless i let the throttle out. i thought it was old gas and oil so i changed that and cleaned the carb out and it still does the same thing. i am out of ideas! any help is appreciated. thanks so much.
