yzf750 Exup Cable
are you still after the length or have you found it i can remove and measure one of mine if you still need it! thanks
FZR 1000
hi never really played wit one of these but does it have a main relay?? are all the earth leads good??? hope you find it
exup parts
hi does anyone out there no if its possible to get spare parts for a exup valve for a yzf 750, i have broken the bit where the cables attach. thanks
Thundercat rear shock
hi sounds like you have broken something internally, the best advise i could give is ebay, there is a company on there there will refurb a shock for £100, or alternativly you could do what i done and buy a 2nd hand one from there it cost me £15 in total. hope this helps
- cant find neutral on yzf 750
hi guys and girls looking for some help again i have a yzf 750 and neutral seems to have disappeared, was then last time bike was running been doin lots of odd jobs got it running again now cant find it, any usual problems?? anyone had a gearbox apart on one, much of a job?? thanks- xj 750 f carburetor
hi if they are very small holes you can sometimes get away with smearing silicon on them as this still has enough flex in it so it can work properly- cant get wheel to fit
hi thanks for your reply had another go today at getting it in, the spacers can only go one way because of the dust seals, they definetly seat in properly wondering if i have a wrong space the wheel was tight coming out but i just assumed it was because the bike has been stood for over a year. thanks gain- Fzr-RR 400 questions!
hi there as someone else said deltabox is just the frame design, you should find the model on the vin plate near the headstock. dont no about the fairings and headlight unless you are any good with a tin of filler and paint!! beware with the rear wheel as i no on the 600 there is a 18 inch on early models and 17 on the later ones! hope this helps- FZR Hugger
hi dont know much about fzr's although i have a foxeye trackbike, the only i would say becareful of is that there is different size wheels so may be an issue, worth checking!- cant get wheel to fit
hi everyone decided to join this forum as ive been looking and it seems theres a lot of clever people here and i need some help, i removed the rear wheel from my yzf 750 changed the tyre now cant get the wheel to fit again, ive looked at a diagram i have it all right it just wont fit seems about 1/4 inch to wide. anyone ever know a swing arm to bend/distort??? only just got the bike so never had wheel out before! thanks- fzr 1000 ru ignition stress
most four cylinder engine fire this way but usually the leads go to 1 and 4 2 and 3 hope this helps - cant find neutral on yzf 750
craig88
Joined
Last visited
