yossp
  1. hi. i took new air filter of replaced with old stadard one tightened all pipes up and twisted air/tick over screws and seems to be ak now.touch wood. hope gets me to work today without any probs.fingers crossed.just want to say thanks for feedback/ advise you gave me.cheers.
  2. cheers again.i suck on little hose and fuel comes out big one.no fuel comes through the little one.think i might buy new fuel cock.replaced everything else nearly so far and still this problem. thanks for your efforts.
  3. hi.thanks for help.the vacuum pipe connects straight to the carb. i havr sucked pipe and fuel comes out. maybe vacumm tap going wrong when i use more throttle.? greatful for any tips. as just brought new carb/air filter and bike still dodig it.
  4. hi.i have a 2006(06) yq50r. just started fuel problems. the idle speed is ok but when i pull away it moves of then seems to starve of fuel.i have put a new carb ,manual choke and air filter on it.it happened with my old carb to. thought i would just replace the carb but still same prob.could it be faulty vacuum fuel cock. please help as this is doing my head in.have cahanged the cylinder and piston.new carb.air filter. what else could it be.i fine on tick over. so basicaly fine start, pull away then when seem to hit 20mph ish it seems to starve of fuel.but when i stop it does not cut out.
