JORDAN-432
  1. whats the standard needle poisition for my dt125r 2000
  2. is it ok just to buy the rings or should i get the whole piston kit? Nothing is damages just would like to put new rings in
  3. looooooool
  4. no didnt go that far, i was going to split it as i thought there was a problem with my gears were inside the gearbox but it turned out to be the gear selector shaft.
  5. well when i rev it over about 3k it vibrates quite bad. An unbalanced clutch is when the plates inbetween the friction plates aren't balanced because a bit of the plate has been taken off so you have to put them in evenly. I put them in as evenly as possible but just not sure whats wrong with it and thought this could be it.
  6. i recently had my engine out because the gears weren't right so i sorted that, now i think that the clutch is unbalanced. can anyone tell me the symtoms of an unbalanced cluth please.
  7. i dont no where i disconnected them from , i thought it would say it in the haynes but i guess not.
  8. hi, ive just put my engine back in and theres 3 black pipes coming from the carb can u tell me which one goes to where. Thanks.
  9. would i have to split the engine get to this
  10. When i go into first or am going down gears when i push the gear lever it dosnt spring back up so i have to pust it up with my foot. anyone one whats going?
  11. to much air of maybe an air leak if the chock has to be on all the time?
  12. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200466051141&ssPageName=STRK:MEWNX:IT There you go
  13. Does any one no the width of the standard manifold.
