steve-y
Everything posted by steve-y
  1. Up date on situation I've managed to resolve my break light problem, all wired and working correctly. I've also bumped the bike a few times with no issues, starts easy... However, still haven't found the cause to the start button.. When i've bumped the bike off and got the engine running, all lights work fine until i put it onto high beam.. then both the clock lights and beam go off.. I'm going to check the parking the bulb and main to see if either are faulty, in the hope that this is the cause of the faulty start button.. on the same loop i think later all
  2. Alot to take in and I'll be checking quite a few things by the looks of things.. Just to answer a few questions. I do hear the power valve fire up when i turn the key and the display lights (including the neutral light). Bump start is what i meant -- sorry --- I haven't checked the side stand, but i when i attempt to start it, its always up and like i previously explained pressing / pushing the starter button gives me nothing.. I've been out to have a brief look at it today and the left side indicators decided to play up a tad today = when pressed it decided to flash in hazard mode for a while, then decided to go back to norm.. As far as i am aware with regards the fuses, it only has the one which is situated next to the battery and if this had blown, then i would not of got anything from horns etc. Then again i maybe wrong. I'll have a quick look over the wires again and i hoping a pal from work can do a quick circuit check for me... but from the feedback here, i am hoping its something simple... I'm going to check the earth leads, as someone suggested that maybe the cause.. apparently it has numerous ones across the bike... Thanks again people and i'll keep you all posted on progress steve
  3. HI all Just starting out in the biking world and i have purchased a TZR 125. All was well but with bike, running nice and everything as normal as could be. However, I returned to the bike next day to discover that when turning the ignition on and attempting to firing it up via the start button, nothing.. i did however manage to jump start it and being a new, that was a pig to do.. I checked what i could, battery - fully charged, horn and indicators - both worked fine. Then moved onto head lights, nothing and the both foot and hand brake nothing.. as well as the igintion start button.. I've looked at the wiring diagram in the hope that i could make sense of what might be the cause, but i'm no wizard and have basic knowledge of electric's. So i'm hoping that you fine people on here maybe able to point me in the right direction... please thanks in advance ps new to forums too so be kind
