My TZR125R BELGARDA 4DL series 1 1992
Some of the rebuild pix ---------------------------------------------------------------------------------------------------------------------------------------- Well peeps, not been around on here for a while, but i have finished my TZR, this week and fresh MOT end of the month. here is my web site for the specs etc... http://tzr125r.pen.io/ but just to show you how this bike has turned out. It runs flawless, and goes like stink.sounds great, .It rides good as it looks! Roll on my next project. 2012
De Restricting my DT125R
hi guys, i owned a dtr 125 r 2003 model and de-restricted it. 90mph and full power all the way up the power band. The speedo has a reed switch, pull it out, away from the clock face, tape it up and leave. exhaust, either go down the full DEP route, but i didnt like the dep. too toppy for me, 8K power band..mmmm Use the original, but cut the restrictor out of the flange, like in the first post, and then cut along the seam in the expansion chamber, open up the zorst, knock the two bits of metal "wind breakers" out. TIG reweld the two halves back, in perfect postion again.The original zorst produces better power IMO. some of the newer RE`s and X DTR`s have a carbon CAT in the front of the pipe. this needs to be taken out too, or just buy an older zorst. carbs..mmmm.. standard is 28mm flat side or even older 90`s is a 26mm mikuni`s , just make sure the jetting is perfect. if you can, find a TZR125R Dellorto 32mm with the inlet rubber + reed block that will make a huge difference. The TZR125R 4DL model has the shares the same engine, just the CDI and the carb + exhaust makes 33HP the standard cylinder head is designed for lower compresson, change it also. to say a 4FU, the compression will come up. http://www.ebay.co.uk/itm/Yamaha-TZR125-93-97-DT125-TDR125-Cylinder-Head-13815-/280716578375?pt=UK_Motorcycle_Parts&hash=item415c030e47 hope it helps..
Yamaha TZR 125 (1989) Bodywork
which model is it?.. 2RK?
choaw dude, am getting it sorted. got the fairing trial fitted, with rad scoop today decals fitted also.
Bought this awesome peice of kit for a grand sum of 250 quid. In a bad running state, but the condition is prety good. Only done 17.4KM in pounds and pence a smidge over 10K miles. 34HP, Brembo wheels/brakes delorto 32mm carb italian import. UK road reg`ed. box of spares too.. plus the most of the fairing, big big smile!.. going to take a wee while to get back on the road. fitted the bits toghter just to see what the bike looks like.. on with the restore! engine is now out, needs a new crank bearing.. slight play.. the fork seals are knackered..too new bar ends and grips, and a bloody goo clean up.. forks back on with new seals. along with a new tyre looking not too bad... so far.. needing a starter motor, and screen.. small list of parts iam trawling the net for.. also i seen these.. 400 quid!.. i like alot.. ongoing..still...
i got a feeling, the squish band on the 3bn head is trapping compression, u think that my head has 1mm taken off. the piston is quite close to the douhgnut area. gases are pretty squished in the recess. probs explain why gaskets go pop quit a bit. lookin out for a 3mb head now. i need 13:1 compression... also been looking into better head gasket design, bout to talk to these guys. custom made! http://www.ferriday.co.uk/copper/copper.shtml
Yamaha DT 125 R Revs Help.
mmm sounds like the bloody plug to me trying to break down. and i suppose the coil could do the same if say was slightly faulty.. Another thing thats well over looked is the pickup from the flywheel, dead easy to get at, just need to take the flywheel cover off, have a look at it, to see if any rust has formed on the head of the pickup, or even small metal fillings. Give it a good clean. other than that it is starving of fuel. that could be many reasons. Float level, flow, jets/needle position..bla bla bla..
dt125r
wow, a rarer red one, not often u see many that colour now adays. Yup you will have fun with seized bolts n stuff, its an art to get them out for sure, if u can, give them a alot of heat too if ya can, the stuff i use is a PLUSGAS, its a spray we use at work. Hit it with the blow torch too.. other than that is drilling the little buggers out, tap n die set and some new fresh bolts pref stainless.. good luck, its all fun, u`ll work through it.. great lookin bike chap..
Overheating DT125R Help pls
yup normal water is fine, u would need an antifreeze in the winter.Never heard such horrlicks! with adding stuff to water for this or that or other. come on use your sense. not only that, u instantly told me earlier that i was wrong about an exhaust!.. common chap.. pls make 100% certain ur right before flaming. make u look like a right pratt. DTr are terrible for holding head gaskets. Useless design IMO. the gen yam gaskets seem to work better, but why ohh why did`nt yam use O ring technology.. or better gasket design..the head is so small no wonder its warps. and gettin a torque wrench on the head!.. whilst in the frame.. im thinking of changing the design my self. plain copper gaskets. laser cut!
Stuck between Yamaha DT 125 Or a Kawasaki KMX
hey ya old git, justa question really, what year was your pipe?.. u may or not know the later pipes had 2 half moon shaped metal peices in side. this was to slow the gas`s in the expansion chamber. Also a restriction tube in the front. Which u cut out and open up the size of the neck. The older pipes say for the 95-98 models.. did`nt have this in them, just the neck restriction. The really new pipes say the RE models have a catalytic converter in them. pls take ur time reading this. http://dtr125.net/tuningnewer.htm The DEP and many other pipes, powerband comes in around the 7.5K revs. full chat 8-10K. Ideal when ya need full power on a small track. Crap for road use. The orignal yam pipe, was sec made for the DTR, tuned. When deres`s, the power band kicks in at 6K. Ends about 10K. When ur using the bike on roads, ur still pulling in 6th gear at 6.5K unlike a DEP, which power would come off, and u would change down to 5th. So the original pipe pulls harder and stronger.
oooooo.. just found this thread..My DTR compression is high, the lip near the squish area.. on the 3BN has ben taken off..But i have encountered a problem.. it keeps blowing head gaskets. I wonder the 3MB version would help. Yam have said there are diffent head gaskets! The TZR RR model has a higher compression, i would love to know what head it uses. I got a feeling the 3BN design was for the lower compression DTR engines. Also the TZR RR uses the 32mm carb. unlike the 26mm mikuni.. any way brill thread guys!.. love it.. PS.. my new cookoo clock! well DTR bottom end, ive built.. PS2.. got some interestin info for ya guys regarding over sized pistons and PV`s.. not good!..lol
dt125r
8K!!! u lucky git! on a H plate..thats awsome!.. all elbow grease rally.gunk every thing!.. power wash every thing. new oil, clean carb, free brakes!.service all the cables. grease gun the swing arm linkage, check bearings for play.. Spend a bit on tyres . chain..pads.. give one hell of a service!. U will have a great bike!.
DT125R Carb tunning
not another 1, 210 is right on a stock motor, right compression! the 26 mikuni is a really great flat side carb. Only way to increase power is increasing the compression. better port timming, and a better zorst. The best guy to do any 2T work here in the UK is Stan stevens. google him.. TIP ..Have a look at the TZR RR spec..same engine as the DTR, u will notice some nice differnces! bigger carb!.. bigger compression. stage 3 barrel timmings!. And if u find a TZR RR model..give it to me..lol!...
thats two peeps l8tly with he same problem..why did ya pin the pv open?..curious 9k!..mmmmm..did u do a top end rebuild, checked compression std is 110PSI on a new engine! , check spark plug gap, changed the plug even!..mines revs to 11k and the power band comes in at 6K... The zorst decoked?.. all boost bottles on. air filter cleaned.. gearbox oil at the right level.. right oil in there too, not like 20W50 engine oil.. grrr.. does it drink fuel? badly. tip for ya.. DTR`s eat plugs! dont ask, i dont know why, still working that 1 out! got a feeling its the shit coils! I use NGK BR9ES, only got to look at it, and it fails!..lol so many questions!
hi ya chap. i have owned 2 KMX125 and a KDX, great bikes, but bloody exspensive for the engine, esp on the barrel replating. 90 quid a time to replate. The DTR costs me 20 quid! for a rebore!. go figure..lol, Never had problems with the front brakes, i must of been just lucky..lol Now,I currenty have this.. Done 8K miles in less than a year, 1 top end rebuild! so far, and it goes off the clock at 80mph. Has the gutted original zorst, not the DEP. more power! Vee rubber tyres, renthal bars. I love this thing!. its the nuts! DTR deff. Ohh and it does 55MPG. or in other words 105 miles before it hits reserve. the tank is 2.2 gallons, 1.8 gallon with out res,..about 130 miles on a tank!. Off road, its great, feels tight, and jumps well n balenced, I have changed the bars and stifferned up the rear too tho..orginal DTRs setups are a little too soft for me..The mono shock has a little bit more tension now. on road with the right tyres. almost knee down, takes a fair bit of doing as the bike is quite tall. power out of a corners, banked feels great!. never had a tank slapper yet..lol... differnt story in the wet tho..lol..heheh..I use vee rubber VRM056 rear, lasts about 3K mainly road use. Bridgestones are really good too. more suited to road tho.. The forks are very capable.. the frame forgiving, down falls, the original rims get rusty quick, cheapo! chineeese rims i expect. The paint on the frame seems to flake a liitle here n there, nothin to sort really...... umm... thats it really for me! DTR all the way for me, cheap to fix, cheap to run, and a very good quality 2T...good luck on your choice. ps.. the DTR forum is a great place to live as well!.. chooaaawwww
