nexusnode
Everything posted by nexusnode
  1. I had a look at all the bits mentioned above but none of them solved my issue. I have solved some of the problem though and thought I would post on here to let you all know what I did. I found that the gear shift shaft was floating a lot inside the engine casing and when at one extreme it was rubbing against the back of the clutch housing. This had the effect of making changing gear problematic which produced the false neutrals... Now I have a copy of the official service manual and I can't find any mention of anything that restricts the shafts float. (Please correct me if you know any different) I ended up making a spacer between the shift lever and engine case to force the shaft into a good position. I also put a washer on either side of the spacer to make sure it doesn't cause any damage. It has since made my gear changes very smooth.
  2. I'll be honest guys, my first post (not that long ago) was requesting some help - clicky. As it happens I was looking for a community to get involved in, and found you guys after searching the net for answers to the problem I was experiencing at the time. Unfortunately the response I got was a wee bit on the grumpy side and as a result its taken me until now to revisit the forum as I didn't feel welcome. The point I am trying to make is that I think you need to be careful tarring everyone with the same brush, it potentially just damages your user base. Anyway, I am back now to follow up on the problems that I was experiencing and how I fixed some of them, as hopefully it will be useful for others in the future.
  3. sounds like good advice, I will get those all looked into as soon as I can and let you know. Thanks again!
  4. Once again, thanks for the link. Apologies, I assumed that because you are a moderator that you would have some say about the performance of this website and its forum. If I am honest though, the false neutrals whilst a pain in the bum - I can live with so long as I don't think they are causing damage. The bit that is concerning me more is this bit: After reading all of those threads , none of them appear to have anything like this in them. Any ideas? Thanks in advance
  5. Thanks for the links, please can you fix your search.
  6. Thanks for your tips I will give them a try. I would like to point out though that I did search your forum first and found nothing. The only posts related to this model when doing the search "ybr125 gearbox" is one that is about a fuel cock and a second that is about lost keys... I might be new to this forum, but it does not mean I am ignorant of forum etiquette.
  7. Hi all, thanks for reading. Am hoping someone on here might know a bit more about clutches and gearboxes than me and be able to tell me whether my guesses are right or not. I think I have two seperate problems but they might be connected... First one is about false neutrals. Reasonably often my bike doesn't like going from 1st to 2nd and just goes into neutral, not quite so often it does the same thing going from 3rd to 4th. It tends to happen when I am accelerating (relatively - its a 125 so not really) quickly. At first I thought it was just me being rubbish and not making a strong enough change action but I don't think thats the case any more. I commute to work and back along a strip of 50mph road, the last few days that I have been out whilst going along here in top not accelerating the engine has for about a second or two started revving like it either wasn't in gear or like the clutch hadn't engaged. But then after a second or so - without doing anything it sorts itself out. Thanks!
