kishan
Everything posted by kishan
  1. kishan replied to Scan's post in a topic in New Members Welcome Area
    welcome
  2. kishan replied to Sultan3458's post in a topic in New Members Welcome Area
    welcome
  3. kishan replied to rickey52's post in a topic in New Members Welcome Area
    welcome
  4. kishan replied to MadzeR86's post in a topic in New Members Welcome Area
    welcome tell us more about yourself
  5. kishan replied to Sammyt80's post in a topic in Yamaha Gallery
    hahahahahha that made me laugh btwn ice lil bike hope you enjoy using it
  6. kishan replied to FZRDAN's post in a topic in New Members Welcome Area
    welcome
  7. kishan replied to 95V's post in a topic in New Members Welcome Area
    welcome
  8. kishan replied to kishan's post in a topic in General
    not a fan of playing with performance as you change one part then you need to change 1000 other parts never ending cycle. think the piaggio typhoon125 should be fast enough to get me out of trouble and etc
  9. kishan replied to James Roland's post in a topic in The Bar
    welcome
  10. kishan replied to Razer100's post in a topic in New Members Welcome Area
    welcome
  11. doh !
  12. kishan replied to Duff 1's post in a topic in New Members Welcome Area
    welcome
  13. kishan replied to kishan's post in a topic in General
    Yamaha aerox100 - Type : - Displacement : - Max power : - Max torque : - Starter system : - Lubrication : - Carburation : - Fuel tank capacity : - Transmission : - Ignition : Air-cooled two-stroke single 101cc 5.5 KW @ 6800 rpm 8.8 Nm @ 4500 rpm Electric and kick Auto lube TK 7 litres Automatic, V-belt CDI - Overall length : - Overall width : - Overall height : - Seat height : - Wheelbase : - Min. ground clearance : - Dry weight : - Front suspension : - Rear suspension : - Front brake : - Rear brake : - Front tyre : - Rear tyre : 1746mm 690mm 1170mm 828mm 1259mm 146mm 87.5kg Hydraulic telescopic fork Swingarm with hydraulic single shock 190mm disc Drum 130 mm 130/60-13 140/60-13 - High-specification sport commuter scooter - High-performance 100cc 2-stroke engine - Full-sized chassis - Long, well-padded dual seat for two-up comfort - Large diameter 13-inch wheels - Powerful 190mm diameter drilled front disc - Analog instrument panel
  14. kishan posted a post in a topic in General
    Im thinkin of part exchanging my 2004 yamaha aerox100 for a piaggio typhoon125 2011 below is the link yea or nah? http://www.bikez.com/pictures/large.php ... iaggio.jpg General information Model: Piaggio Typhoon 125 Year: 2011 Category: Scooter Rating: 75.3 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 125.00 ccm (7.63 cubic inches) Engine type: Single cylinder, four-stroke Fuel system: Carburettor Cooling system: Air Gearbox: Automatic Transmission type, final drive: Belt Driveline: CVT automatic speed variator Exhaust system: Euro 3 Chassis, suspension, brakes and wheels Frame type: Steel tube Front suspension: Telescopic fork with hydraulic damping Rear suspension: Single spring with pre-load hydraulic damper Front tyre dimensions: 120/70-12 Rear tyre dimensions: 120/70-12 Front brakes: Single disc Front brakes diameter: 220 mm (8.7 inches) Rear brakes: Single disc Rear brakes diameter: 140 mm (5.5 inches) Physical measures and capacities Weight incl. oil, gas, etc: 113.0 kg (249.1 pounds) Fuel capacity: 7.50 litres (1.98 gallons)
  15. kishan replied to 78dt125e's post in a topic in New Members Welcome Area
    welcome
  16. kishan replied to 125Viking's post in a topic in New Members Welcome Area
    welcome
  17. Hi
    kishan replied to 67Wardy's post in a topic in New Members Welcome Area
    welcome
  18. kishan replied to Sammyt80's post in a topic in New Members Welcome Area
    welcome
  19. kishan replied to lingel's post in a topic in New Members Welcome Area
    welcome
  20. kishan replied to fatcat's post in a topic in New Members Welcome Area
    welcome
  21. kishan replied to Tommy Boy's post in a topic in New Members Welcome Area
    welcome
  22. kishan replied to Zombi's post in a topic in New Members Welcome Area
    welcome
