kishan
Everything posted by kishan
  1. welcome
  2. welcome tell us more about yourself
  3. hahahahahha that made me laugh btwn ice lil bike hope you enjoy using it
  4. welcome
  5. not a fan of playing with performance as you change one part then you need to change 1000 other parts never ending cycle. think the piaggio typhoon125 should be fast enough to get me out of trouble and etc
  6. kishan replied to James Roland's topic in The Bar
    welcome
  7. welcome
  8. welcome
  9. Yamaha aerox100 - Type : - Displacement : - Max power : - Max torque : - Starter system : - Lubrication : - Carburation : - Fuel tank capacity : - Transmission : - Ignition : Air-cooled two-stroke single 101cc 5.5 KW @ 6800 rpm 8.8 Nm @ 4500 rpm Electric and kick Auto lube TK 7 litres Automatic, V-belt CDI - Overall length : - Overall width : - Overall height : - Seat height : - Wheelbase : - Min. ground clearance : - Dry weight : - Front suspension : - Rear suspension : - Front brake : - Rear brake : - Front tyre : - Rear tyre : 1746mm 690mm 1170mm 828mm 1259mm 146mm 87.5kg Hydraulic telescopic fork Swingarm with hydraulic single shock 190mm disc Drum 130 mm 130/60-13 140/60-13 - High-specification sport commuter scooter - High-performance 100cc 2-stroke engine - Full-sized chassis - Long, well-padded dual seat for two-up comfort - Large diameter 13-inch wheels - Powerful 190mm diameter drilled front disc - Analog instrument panel
  10. Im thinkin of part exchanging my 2004 yamaha aerox100 for a piaggio typhoon125 2011 below is the link yea or nah? http://www.bikez.com/pictures/large.php ... iaggio.jpg General information Model: Piaggio Typhoon 125 Year: 2011 Category: Scooter Rating: 75.3 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 125.00 ccm (7.63 cubic inches) Engine type: Single cylinder, four-stroke Fuel system: Carburettor Cooling system: Air Gearbox: Automatic Transmission type, final drive: Belt Driveline: CVT automatic speed variator Exhaust system: Euro 3 Chassis, suspension, brakes and wheels Frame type: Steel tube Front suspension: Telescopic fork with hydraulic damping Rear suspension: Single spring with pre-load hydraulic damper Front tyre dimensions: 120/70-12 Rear tyre dimensions: 120/70-12 Front brakes: Single disc Front brakes diameter: 220 mm (8.7 inches) Rear brakes: Single disc Rear brakes diameter: 140 mm (5.5 inches) Physical measures and capacities Weight incl. oil, gas, etc: 113.0 kg (249.1 pounds) Fuel capacity: 7.50 litres (1.98 gallons)
  11. welcome
  12. Hi
    kishan replied to 67Wardy's topic in New Members Welcome Area
    welcome
  13. welcome
  14. welcome
  15. kishan replied to Zombi's topic in New Members Welcome Area
    welcome
