corby lad
Everything posted by corby lad
  1. hi ok i took carbs off everthing is moving as should be i put everything backtogether still difficult to start
  2. ok i put my hand in had a feel there is 4 cylender like valves that i can push up with ma fingers is this what am looking for?
  3. hi no sorry i can not seeinto the carbs from were the filter is as it is blocked off when you pull the choke out everything seems ok visualy
  4. hi thanks for reply yep the filter is in nice and snug sorry i do not know how to check the butterflys
  5. Hi can anyone please help i have 1990 xj600 roadster only bought the bike recently so i dont know the bikes history the bike didnt have a air filter and the filter housing was broke so i got new ones now its very difficult to start the bike and it seems to lack power best way to start it is to remove the seat and cover the airintake completely with ma hand then it seems to start ok but it rouns really rough untill running new plug made no difference it seems to run ok once heated although when pulling away if you give it too much throttle it seems to hesitate any advice is well apretiated cheers
  6. hi thanks just ordered one oo i love ebay thanks for your advice
  7. hi bud corby just outside kettering ok ajusters on both end traditional on the hand lever and 2 nuts either side the bracket lower end am sorry can you explain again for me? am stupid lol ive got the cable on but am sure its not ajusted correct as its dificult engaging neutral now
  8. hi can anyone please tell me best way to ajust a new clutch cable i have it fitted just need the info how to set it up many thanks
  9. Hi i checked today the Grey feed from the ignition unit is ok there is no breakage in the wire and there is 12v suply to the tachometer ok here is a question will the tachometer from the newer models fit inside the pre diversion model? many thanks
  10. cheers bud will get out the multimeter the morra
  11. Hi i have a 1990 xj600 its a cracking bike am tidying it up i have a good knowlage of bike mechanics could anyone help me trace the problem with the rev counter its dead many thanks
