gaurav
Everything posted by gaurav
  1. Dear all, i need u r help regarding the installation of K&N filter in my bike air intake system the specifications of my byk are as follows Engine type Air-cooled, 4-stroke, SOHC, 2-valve Displacement 153.0cm3 Bore & Stroke 58.0 × 57.9mm Compression ratio 9.5:1 Maximum output 14PS / 7500 rpm Maximum torque 14 N.m / 6000 rpm Starting method Electric starter Lubrication type Wet sump Carburetor type BS26 Clutch type Constant mesh wet multiplate Ignition type CDI Primary/secondary reduction ratio 3.409 / 2.857 Transmission type Return type 5-speed Chassis Frame type Diamond Suspension (front/rear) Telescopic / Monocross Wheelbase 1,335mm Brake type(front/rear) Hydraulic single disc / drum Tire size (front/rear) 100/80-17 / 140/60-R17 dimensions Overall Length × Width × Height 1,975mm × 770mm × 1,045mm Seat height 790mm Wheelbase 1,335mm Minimum ground clearance 160mm Dry weight/Curb weight 126 kg / 137 kg Fuel tank volume 12 liters Engine oil volume 1.2 liters 1)is it advisable to install K&N filter ? 2)is there any calculations for the selection of k&n filters? 3)is there any changes required in caeborature ? 4)r there any other methodes to improve the BHP of power ?
