Speedshop
Everything posted by Speedshop
  1. more likely the field windings. Remove the brush block and measure between the 2 copper tracks. Less then 4.5 ohms bad so is no reading.
  2. Ta-Dah! you won't need capacitors, just a voltage limiting resistor as per the diagram I'm sure you could use a simple BC547C series transistor in place of a relay. Not tried it, but these are very cheap and easily available.
  3. If the keys are the sort with chips in them, you're looking at main dealer parts only which will have to be programmed to match the ecu. Don't buy these parts off ebay as you'll never get them to work, the equipment needed to match locks and keys to the ecu simply isnt available.
  4. I'll draw you a picture to show how you could get this to work when I get 5 mins
  5. I was going to say..... I'd work out a resistor for 14.7 volts and place it between the centre connection (2) and earth. Then connect the feed from the hi beam to one side and from the neutral the other...... The big flaw in that is that the hi beam works when a voltage is applied - the neutral works when you apply an earth to a live feed.......... Which means you'd only ever see a hi beam indication if you were in neutral. So unless you used a relay where the bikes neutral circuit operated the relay control coil that switched a live feed on to the LED when in neutral, it ain't going to work. The other thing is don't these show 3 colours? 1 for each side of the diode and the combined colour when both sides are powered?
  6. The DT250F is different its the F8T800 box. This is our part number DT5 We don't have stock at present, lead time is approx 2 weeks. I've been building a comprehensive data base for these bikes. I've started work on it you can see how far I've got on my website (link below). I'm about 50% there with the IT/DT/YZ/MX machines 73-82.
  7. That should be no problem running just the cdi with no lights, just leave the plugs from the generator that don't connect to the CDi un connected. Yes we accept pay pal, you can also use a normal credit/debit card at the check out. If you e-mail [email protected] we can send a money request.
  8. We have the 00172 unit -new- for £77.00 plus £8.85 shipping to Canada. Comes with one year warranty. I think that compares well to a second hand item that could be 20 years (plus) old.
  9. we make a cdi for the IT250. I'll see if we have a wiring diagram for it.
  10. regulator/rectifier
  11. Speedshop replied to LiamDTR's topic in The Bar
    I can't help with such a late model, if it were a 70/80s model we have a range of new wiring looms. £100 for oem seems cheap, price up the cable, sleeving and connectors you'd need to build your own!
  12. Hi There I'm guessing the floods have abated! I've been round northern europe, Down as far as Bologna Italy, mainly on my Triumph Daytona, but the XS650 has had several trips out to France Germany and The Netherlands. I spend two weeks out on the road going to Italy, not much really but you get a sense of being separate from the rest of society as they run around in there little tin boxes. France was good, I stayed away from the main routes and found some fantastic roads - wide, open no traffic, I went 20 miles and saw only 3 or 4 cars at one point. Italy was hell as it August and stinking hot, it was 42C one day, 29 at night. Despite what most people think about Italian drivers I found they looked out for bikes and took more care around them, I guess so many people have scooters there they are used to looking for them. I stupidly decided to make some time and headed for the autostarda, only to get stuck in 5 mile jam. A very heavily loaded bike in the sun, full leathers and trapped by queues of fume belching trucks was hell. I was cooked and muscles shaking as I fought my way through it all. When I stopped for fuel people were looking at me, with my helmet of my face was black across my eyes and the sweat was making all the dirt run. happy times!
  13. Speedshop replied to Airhead's topic in Classics
    you'll never get good results if you don't do proper prep. This is why plating is so expensive to get decent job, the prep takes much longer then the actual plating.
  14. If you are after ignition units or related info, we now have a comprehensive range of new units for 1970/80s YZ/IT/MX/DT 125/175/250/360/400
  15. the best way to improve the lighting would be to mody the wiring to use relays to control the on/off and hi/lo functions..........google it I'm not going into all lol.
  16. I take it with the short pipe you still have the exup valve fitted and connected? The rev counter going blank shows that there is a system fault; could be because the ecu lost contact with the exup valve. maybe a loose connection?
  17. try Dave Newett at motorcycle restorations. He is very clued up on XTs. Www.Yamaha-XT500.com. all lower case.
  18. thanks i'll have a trawl through later
  19. Hi I'm trying to find if the ignition pick up on the DT360 is the same item as the DT400. A similar generator was also fitted to the YZ400 but the ignition is different, they may have used the same pick-up though. . If anyone can post nice clear pictures of the CDI 1977-8 DT 400 (also 250) generator or can say for sure if the ignition pick up is the same - I'd be grateful
  20. Speedshop posted a topic in The Bar
    The 'Speed Shop now offers a replacement CDi unit for the DT360. http://cgi.ebay.co.uk/Yamaha-DT-360-CDi-Ignition-unit-new-DT360-/190494987816?pt=UK_Motorcycle_Parts&hash=item2c5a62d628
  21. Our ebay auction to raise funds for the Queensland Flood appeal was a great success. We auctioned one of our ignition units which sold for £68.00, which on 26/01/11 equated to $110 Australian. This sum was sent via the official web site and the receipt is attached. The winning bidder was in the UK and choose the Harley MT350 unit. Thank you to all those who supported this appeal. Tax Receipt No: 3236006 -------------------------------------------------- Premier's Disaster Relief Appeal ABN 69 689 161 916 PO Box 15185 CITY EAST QLD 4002 -------------------------------------------------- Date / time: 2011-01-26T07:45:56-08:00 Customer: Mr Marcus Rex Organisation: Rex's Speed Shop Title: Premier's Disaster Relief Appeal Description: All donations over $2.00 are tax deductible Agency: Department of the Premier and Cabinet Reference: Amount Ex GST: $110.00 GST: $0.00 Total Amount: $110.00 Total (excl. GST): $110.00 Total GST amount paid: $0.00 Total amount paid (incl. GST): $110.00 -------------------------------------------------------------------------------------- We value your enquiries and feedback. The Queensland Government is committed to continually improving the quality of our services. Please do not reply to this email as it has been automatically generated. You may contact us at: [email protected] or on 13 13 04 8:00am - 6:00pm (Australian Eastern Standard Time) Monday to Friday (not including Public Holidays) Calls from within Australia are charged at the local rate. From outside Australia, call +617 3405 0970, +10 hours UTC.
  22. Noted about the scam sites. I will be ensuring the money goes to the right people and obtaining a publically checkable receipt.
  23. Rex's Speed Shop is holding an auction on eBay to raise money for the Queensland flood relief. We are auctioning one of ignition units and all profits will go to the appeal. The winning bidder will be able to choose from our current stock list. Ebay item 190491019174 Please repost this on other forums and bid generously. I'll keep you informed of how much we raise. The total will also be on our website www.rexs-speedshop.com
  24. It shouldn't need any adjustment
  25. What year is you machine? Earlier ones had a Nippon Denso generator
