FZR AL
Everything posted by FZR AL
  1. just double check your connectors and make sure they are pushed home correctly it could be something really that simple
  2. FZR AL posted a topic in General
    Hi All, Does anyone know where I can get some mirror extenders for my 89 FZR600 , I am sick off looking at my shoulders in the mirror and not the road , I have did try moving the mirrors in all directions but still seem to have a my shoulders there cheers Al
  3. Welcome steve, sounds like you got a good buy there
  4. FZR AL replied to bukko0's topic in The Bar
    now you have stopped looking can you find me a proper left hand screw driver , and one of those elusive Sky hooks
  5. steve as you have taken the K&Ns off dyno etc and put it back to stock have you put there correct jets in still sounds like a carb issue to me even though you have changed them, stock jets mains #107.5 pilots #30 incorrect jet needle postion?, and check your diaphrams? , last thing make sure your air filter is not clogged
  6. FZR AL replied to FZRDAN's topic in The Bar
    Dan The tacho and temp gauge are on the same wiring circuit , I would chase it back to the conector plug as its probally just a fusty connector, pull it out and give it a clean up and a squirt of wd40 for good measure
  7. FZR AL replied to bukko0's topic in The Bar
    deffo not centre stand
  8. which model FZR have you got funfly3 , twin headlight ? 3HE ?
  9. drewps its not morley its Aberford , not that far from Squires Collier Lane Aberford, near Leeds West Yorkshire LS25 3EB
  10. Is the bike running? sounds like a blown fuse, or bad earth, if it is the fuse and it blows again you need to inspect the wiring in more detail, pull your connectors though and give a spray with some contact cleaner ,or wd40, a mate of mine couldnt get his main beamn and dip to work the other day pulled the connector and gave it a good spray hey presto all good
  11. have you changed the oil recently ?,is it the correct grade, but to be honest I think its time to change the clutch mate £40 on evil bay , but buy news springs as well £10 £14
  12. I would agree on the not enough fuel getting through,as soon as you twist the throttle its dying, can you manually fill the carb bowl and see if it runs , or rigg something up without the tank?, pull your petrol tap and inspect
  13. just read through your post again it was the coils not the CDI which have 3HU on
  14. think you have the wrong ingnitor, not sure if you have the fox eye version, I just taken a piccy for you of mine if it a 89/90 like mine it should have an iggy box like this 3HE check your breather pipes on the carbs
  15. sneak into the bedroom and pinch your lass's hairdryer, gently warm the grip up and use a twisting movement , the heat will melt the glue
  16. FZR AL replied to Choc's topic in The Bar
    before you go down the ignitor route , it sounds to me that its over fueling , are you sure you have the correct jets in should be #30 pilots and #65 mains,starter jet #52.5 make sure they are genuine mikuni as well , they dont like these\cheap chinese copys , have you pulled the plugs what are they like ? I would take it back if you have paid someone to look at it
  17. Just looked at your pictures of your bike before I signed in Mike, stunning bike , got to be a liverpool fan if you have a red and white bike or you would get some stick if you were a toffee :lol: good look with the test ,
  18. you will need to check your oil level again if you are putting a new oil filter in
  19. FZR AL posted a topic in General
    I think I need a clutch for my Fzr 600, its right on the end on the bars lever adjustment , the clutch doesnt slip and is still smooth but when I put into to first it sometimes stalls, and its seems to be getting worse , i took it out last week and stopped at the lights , neutral, I put into first and it stalled with a warm engine and it seeemd like an age before it started again but probally only seconds but I cant have it stalling everytime I go into to first side stand is up so it not the switch, is there anything else I need to check before I part with my cash and where is good place for a cheap clutch kit , if I am going to have a new clutch I want springs, lock nut, oil semi synthetic etc cheers al
  20. If it were me I would bin it, no matter what the repair was like, the tyres are the only point of contact on the road , thats my opinion !
  21. how old are your tyres, shocks , have you stripped and checked your forks ,when did your last replace the fork oil , but it could be the rubber engine mounts that are passed the sell by date ?
  22. FZR AL replied to mickb's topic in The Bar
    Mick, if it was running fine before the carb strip down , theres your answer , i think they need rebalancing if you have not done that yet , have you put new cables or disturb them form the original routing deffo carbs
  23. FZR AL replied to Knight3179's topic in The Bar
    I think for its first start in 18 years the engine sounds sweet the odd tweak here and there, but a good buy , looking forward to more posts knight
  24. have you checked the carbs, jets etc
  25. looking good there knight ,cant wait to see the finished bike :eusa_clap:
