higgo
  1. hi everybody, only my second time on here and still in need of help !! dt125r will start after much kicking run, flat out on choke then cut out. when it does run if you turn the choke off it dies, if you touch the throttle it dies.the carb has been ultrasonical cleaned,new plug and airfilter, fresh fuel and it has a good spark.its doing my head in why wont it START !!!! PS there is asmall white plastic connecter on the right hand side just under the water cooling pipes , should this be connected to anything ? any help would be greatly appreciated
  2. hi, struggling to remove suspension linkage on my 1988 dt125r.There is a small bolt on one side and a large bolt on the other.From what i can see small bolt screws into large one.Small bolt unscrews ok, large one just spins.Need to remove it as i want to get the frame powder coated, anyone got any ideas!!!!
  3. hi, struggling to remove suspension linkage on my 1988 dt125r.There is a small bolt on one side and a large bolt on the other.From what i can see small bolt screws into large one.Small bolt unscrews ok, large one just spins.Need to remove it as i want to get the frame powder coated, anyone got any ideas!!!!
  4. hi,thinking of putting a vyxxn race can on my thunderace.Does anyone know if i,ll need to rejet ????
  5. hi, i want to fit a race exhaust to my 2000 thunderace , would any can for a 1000cc bike be ok or should i stick to one sold specifically for my bike ????
