lcmadman
  1. top bloke yes it has swelled above the cylinder head like you say, today i checked base gasket(while i was there)and removed head and checked gasket seems flat although never trust a pattern jobby they normally warp, my guess is your right and thank you for your support, when you say change the gasket for o rings do you meen without putting another original in? would'nt they melt when temp gets high? or even move with pressure? thank you in advance you've been a great help
  2. hello to all i am left hanging with a fault that is a bit strange basically my bike is overheating,there is coolant coming out of the overflow and the pipes are expanding as if there is a blockage or the prepeller isnt working or thermostat as of yet i have ripped out the coolant system(radiator,all pipe and also checked the water prepeller on gearbox, i do not have a thermostat fitted either the bike on revs idles strangly eg 1-3 thousand rpm up and down unsteadily the bike will ride normally for around 20 mins then overheat and fluid comes out every gap it can find any suggestions i would be grateful for,thank you in advance
  3. lcmadman replied to leigh dt 125's topic in The Bar
    have you checked gearbox oil level is correct? also could be bottom end bearings or main crank bearings ;-)
