OllyBongo
  1. no, do you have a wiring diagram available for download? Yes the lights do work and they are shit, also im not sure where there is any other kind of fuses? Under the front panel where the horn is, theres a small white box with 2 wires coming off it is that the rectifier/regulator? the connection looks a bit rusty. I mean the electric start used 2 work, but not for a while now, when i press it, nothing... I added a new switch to the right side handlebar, when the brake is pulled in it makes the back light, light up. it does not light up tho thanks
  2. no, do you have a wiring diagram available for download? Yes the lights do work and they are shit, also im not sure where there is any other kind of fuses? Under the front panel where the horn is, theres a small white box with 2 wires coming off it is that the rectifier/regulator? the connection looks a bit rusty. I mean the electric start used 2 work, but not for a while now, when i press it, nothing... I added a new switch to the right side handlebar, when the brake is pulled in it makes the back light, light up. it does not light up tho thanks
  3. Hi can anyone tell me why the electric start does not work? I have fitted a new battery (sealed) 6A - 12V, new main fuse (there is only one fuse on the bike or is there more). I also have added a new switch to the handle bars and a back break light bulb. When i turn the key on, the only thing that works is the fuel guage. The lights and indicators work when i start the bike (kick-start), also the indicators do not flash they just stay on, the back break light stays on but does not light up when the brake leaver is pulled. The speedometre works, the RPM (tatchometre) does not. The bikes top end is normally 50 sometimes i can get 60 wich is a bonus, but it's crap also need bike de-restricting. Any help would be much apreichated, thanks.
