Divvy94
  1. Hi DaAznRider! I have a XJ600S -94 myself. You will find your unvaluable maintenance bible at www.haynes.com. It costs 42$ and is worth every penny :-) Everything is explained very well and with pictures to go along. You can obviously work on it yourself, and may with proper maintenance have a bike for many years. Any weaknesses with the XJ600? I know of two that I have experienced myself. 1. The fuel tap - it's of the membrane type. When it fails, fuel may flood the carbs and float into the cylinder heads. When you start the engine the next time, all this fuel is ignited, with a risk for possible damage to piston rods and so on. I trashed an engine this way :-( How to check: remove the fuel line from the fuel filter, on the fuel tap side. If no fuel pours down from the fuel tank, its okay. When fuel is pouring; replace the fuel tap. Dont waste money on a repair set. 2. The fuel pump up to -95 model (vacuum type). I changed it 3 years ago, and now it has given in again. From -95 on, I believe the pump is electric. If you have an electric one, you're in the clear. I will now buy an electric pump, change the bracket to fit, and find power somewhere. Good luck DaAznRider! Ride on! Cheers, Divvy94
