Blackthou
  1. Nomad. Easy to check. Restriction is by large plastic spacers in the top of the carbs to prevent them opening fully. It will lose you 30 bhp minimum. Take the top off the carbs to check. You ought to visit www.foc-u.co.uk to learn all there is about Fazer thous.
  2. Hi Nomad. If it's quality and best bang per buck try www.performanceracingparts.co.uk . I've had mine 3 years now. Stainless £120 plus they do loads of types ie round, oval, carbon etc. Top quality and service.
  3. My daughter has an Aerox 100 which she has had from new for 5 years. What is the standard setting for the needle and the mixture screw please as I have been able to acheive a fine balance? The bike either bogs on take off then goes like a rocket with the mixture screw set to give smoothest running on tick over or ticks over less smoothly doesn't bog as much nor pull as well with the mixture screw almost in. Would like to know the recommendations for setting up. Thanks
