tat42
  1. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Goff trike running better and managed to eat up a few miles , still a little misfire , on checking engine noticed small oil leak from head gasket ( nothing runs smothly when you build with old bits and peices ), ordered gasket , about 1 week until it arrives , also orderd new inlet manifold ( small rubber rings ) but still £75 for 3 , I hope this will sort it out !!!! Tat
  2. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Goff 1 beer turned into 2 or so ! Fitted balance pipes and bike reved up tp 9000 rpm , put exhausts on and revs dropped to 6500 , took baffles out and bike reved to 9000 , a little LOUD , I think the boys in blue might be seen regulary in my mirrors , not to sure were to go from here , maybe cut baffles down redune noise a little and maybe the revs to. Thanks Tat
  3. tat42 replied to tat42's topic in Yamaha Workshop
  4. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Goff Very little work done on bike today ( lazy ) been working all day . Did manage to tig up some balance pipes out of 22mm stainless will try and fit tomorrow ( if there is not a beer with my name on it ). I tried pulling out choke when on the move , but not any better , will try plug chop when exhaust back on , I dont think the fuel settings are to far out ( he says hopefully ), weather great for bikes today yet both of mine never see the sun ! Thanks Tat
  5. tat42 replied to tat42's topic in Yamaha Workshop
    Hi XS 750 running better without exhausts on , like a pig with them on , has any one heard of balance pipes ?- pipes joining exhausts together , my mate has suggested this ( he has never been right as yet , but he has to be right one day ) Thanks Steve
  6. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Jim Thanks for your comments , I hope I have sorted out problem , it appears to be exhaust , on taking of exhaust but leaving on down pipes biked reved to 8500 , but still a little work to do . Thanks again Tat
  7. tat42 replied to tat42's topic in Yamaha Workshop
  8. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Goff Things have moved on a little today . Started by putting more fuel to the carbs via balance pipes , problem still there , on swearing a little , OK a lot , decided to take of exhausts but left the down pipes on , 8500 rpm a lot lot better , seems to be a problem with them , bloody ebay exhausts !!! I am going to tinkle more and hope it will get better . Carbs were totally striped as they had stood for 15 years and were like jelly . Thanks for all your help its nice to know that there are good people out there willing to help . Again thanks
  9. tat42 replied to tat42's topic in Yamaha Workshop
  10. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Thats quick ! At 4000 rpm it is like hitting a wall , it splutters and will not rev beyond that ( a gallon of petrol and a match could sort it ) only joking Thanks Tat
  11. tat42 replied to tat42's topic in Yamaha Workshop
    Hi I have lifted the needle in each carb to max , the tap fitted is recomended for Harley's so should be big enough for a little 750 , but I can see were you are going with this and I will try coming out of the balance pipes of the tank to get more fuel . Thanks again , if you have any more ideas be very happy to hear them as I am pulling out my hair ( not much there to start with )
  12. tat42 replied to tat42's topic in Yamaha Workshop
    Hi It is a custom tank , I had a mechanic set the mixture , the pipes have baffles and are road legall . #Again many thanks all ideas welcome ( scratching my head for a couple of weeks 0
  13. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Thanks for your reply . The main jets are 145 , i fitted 170 , but made no difference , the exhausts are 3 singles I dont know the make , the engine is fitted to a trike I have made ,it has only covered 30 miles sinse the build and the plugs look ok . Thanks again Steve
  14. tat42 replied to tat42's topic in Yamaha Workshop
    Hi Yes fitted K and N myself , put 155 main jets in . Thanks Tat
  15. tat42 posted a topic in Yamaha Workshop
    Hi I have xs 750 1979 , it is fitted with kand n style filters , bike runs like a pig when over 4000 rpm , bike had been stood for 15 years , I cleaned carbs out etc , have had ignition timing set but still a pig , any ideas ? Thanks Tat
