		help please
		k boys what is the easiest way to get mixed gas out of the motor my jet rattled out in the carb and flooded it like hell if i take off fuel tank and put my bike upside down as in on the seat to drain it out might take a bit to evaporate lol what options might i have thanks mates
		help please
		fuk fuk fuk carb al djusted to 21 mil but now my spark plug keeps getting wet the jets came lose inside carb and i think i flooded the motor arrgh do i just let it sit or will pulling it behind a car clean it out??
		help please
		thanks mate thats what i did was a hundred mill the bike is running now just having float issues but i got that figured out the only odd thing is that it stalls out when choke is closed but runs when open hmmm confusing the carb is very clean and everything but not sure why it is doing that
		help please
		i figure 75 mil would be close
		help please
		oh for pre mix and at a 30:1 ratio
		help please
		ok boys here goes just not sure how many mil oil to add to 3liters of gas
		help please
		k what is that knob above the pot i don't have it it is missing is that my problem and choke knob is broken but it does not lock open i have to hold it with vise grips haha! anyway that other knob is it important? like i said it is missing may aswell bye a new one lol
		help please
		thanks so much could you please show a pic of the other side of the carb please i think there is a screw missing just above the pot
		help please
		oh you rock thanks man is 20:1 ok ratio
		help please
		thanks mate awesome k so the over flow does not hook up to the big oil line right and if i don't have a tank then i should premix and dissconect the small line and big line? See my bike fired up for a while yesturday but then conked out but i had the big line from the pump to the over flow that is the way it was when i bought it but that line goes to a missing oil rez is that correct? Also is it okay just to pre mix and leave lines off pump for now? Thanks guys i had the bike going for i bit i still seem to have a choke issue can i get a pic of the choke switch please mine is broken it pulls in and out but when it springs in thats when it stalls out and when i pull it all the way out holding it with vice grips it runs :(i need to buy a new choke but want to see a pick of it if i can please thanks again
		help please
		thanks guys but no i have no oil tank that is what is cofusing me and i have two lines going from carb to oil pump is that correct? one line is bigger than the other do i just mix the fuel in the tank then you guys rock thanks
		help please
		please help boys and ladies cause i am getting stressed i don't want to f@#$k up my classic i just want it to run
		help please
		i need to know if i have to pre mix my fuel and if so what ratio and pics of fuel system would be aprecciated not used to this bike i just put staight gas in it and need to know if i need to drain it and add mixed fuel instead plus my bike seems to run when choke is full open and as soon as i shut it down my bike stalls out help is really apreciated
stinkysanchez69
Joined
Last visited
