adar35
  1. same noise in netural position?? if not the problem is your gear box.if it is still in neutral its the connecting rod noise on the crank.be carefull...
  2. adar35 replied to adar35's post in a topic in Yamaha Workshop
    thanks
  3. adar35 replied to gibsog's post in a topic in Yamaha Workshop
    if your bike is a californian model it has a emmission hose go to one of the in let rubbers.check it.
  4. adar35 replied to Paulwhite's post in a topic in Yamaha Workshop
    roadstar 125??? )) sorry dint see your bike.have a compression check.if your bike is weak this is the problem when starting cold bybye
  5. adar35 replied to Paulwhite's post in a topic in Yamaha Workshop
    dear frien.you shold use NGK dr8es-L sparks.and the problem in your bike is the carb balance problem.you should balance them correct.if one of the carbs take more fuel from the others it will not easy start when it is cold.try to adjust the balance screws.
  6. adar35 posted a post in a topic in Yamaha Workshop
    dear the yamaha owner.iam new on this forum.and need some help.the problem is my fuel pump.is it broken and want to change it.but i cant find a 2.hand or brand new in turkey.can anny one help me which fuel pump i can use on my fzr.is a car fuel pump wright?thanks.waiting for your help.
