yazholes
  1. can i make one up out of foam in a steele mesh box. or use one off another bike.. thanks
  2. you guys are great. i dont have an air cleaner on it becouse i dont have the oridgnal one, is that going to be a problum? is there a way around it. thanks heps
  3. hay guys got the old girl going figured out what it was couse the bike had been sitting for so long there was rust on the coil where it bolts to the frame stoping it from making an earth. the explanation on the wiering helped to. thanks for all your help guys . now that i have it running it will idle realy good with the choke on but wont idle with it off what could the problum be. thanks
  4. ok ill check that lead thanks for the effort your puting in.
  5. ok thanks mate. so how do i remove it take the nut off then do i need some sort of puller to remove it. thanks
  6. ok thanks mate ill give that a go, if it is the magneto is there a way to repair it, it sounds like it just needs a cleane up it was sitting in the guys shed for a while and it had mud all over it. where can i buy parts for this bike is there a place on the net. thnaks again
  7. hay mate thanks for your help. i got spark again like i had yesterday but its not enough to arch out the spark plug. i got a new plug and tryed it again but still only a little zap, could the magneto not be sending enough charge. yhar i had my finger on the tip of the plug and it arched through my hand to the kick start there all factry conections and ive unpluged and pluged them back in incase of corrosion. thnaks
  8. i did what you said and i kicked it and it gave me a small zap then i did it a few more times and it wouldnt zap me again what does that mean, shouldnt it be a pritty noticable shock if it zapes me. thanks
  9. another quick reply i like this. cool thanks mate i dont have the black/white wier conected to any thing its just sitting there its just a single wier hay. so does it sound like ive got it hooked up right. thanks
  10. thanks for the super Quick reply ive done as follows magneto wier to CDI magneto CDI red/white to red/white brown to brown black to black to chassis and the orange from CDI to coil. still no spark, the only wiers that have power from the magneto are the yellow and green is this normal if so how do i get power to the CDI. the kill switch can be left disconected hay. thanks
  11. hi i have just brought a realy cheap dt 175 sight un seen (silly move i know) and i just found out why it was so cheap the wiering is all disconected. i was woundering if i could get some help please. the magneto has 6 wieres: brown, black, red/white, yellow, green and blue the CDI has 6 as well but in 2 lots of 3: lot 1: brown, black, red/white lot 2: black, black/white, orange im gessing the brown, black, red/white on the magneto go to the same colour on the CDI but where do the rest go? and there are all these other wiers do i need to do any thing to them or just get rid of them. im just riding in the bush so i just gota get the old girl runing any info is good info thanks
