UncleDave
  1. I know this is an old thread..... The seats are both different.
  2. prefixed with "the" assume a pub! maybe this?My link
  3. Is anybody going. I'm planning to go with some friends - anybody else going/interested. It should make a fun little outing It's about 2000km , spend 3-4 days going there, festival for the weekend then down to the Croatian coast for a few days before coming home.
  4. Yes they can.... I thought I'd take a chance at £26 for the windscreen and lower deflectors!
  5. UncleDave replied to Cynic's topic in The Bar
    Now you gonna have every fag on your arse for saying the "G" word!
  6. Check this out: http://www.vsoc.org.uk/vsoc_faqs/vsoc_faqs.htm#noisestart The voltage test without any load, may indicate the battery is fine, but when you put it under load, like starting, a bad cell (or two) may be the culprit, not allowing all the current (amps) available (upto 230!) to go through all the cells to reach the starter. To test for this, do a voltage check across the battery when you hit the starter....if it drops from say 12.2volts to 10volts, you've got a bad cell..... I've also seen this on my travels - http://vstar.brazilmission.net/VStar_Starter.pdf UD
  7. This is part of my homework ;-) Nice photos btw!
  8. Last one (for now). Will a 650 Classic screen fit an 1100 Classic? Thanks for the patience. UD
  9. Thanks for the quick answer. UD
  10. Can a stock Yamaha Dragstar screen fit on any Dragstar? Specifically - could I fit a 650 Custom screen on a 1100 Classic? Thanks UD
